E-Class (W211) 2003-2009
W211 SCN Coding (variant coding) EGS52
Old Today | 03:57 PM
tommyde's Avatar
Cool W211 SCN Coding (variant coding) EGS52
Due to a fault in the differential of the W211, I replaced it with a different differential.
As the new differential does not come from the same, but a similar engine variant, the sensor system is now triggering an error message stating "gearbox slip" and the car is entering mechanical emergency mode.
This is a consequence of the fact that my differential gear ratio has now changed from the original 3.46 to 3.67 or 3.27.
I have used the Vediamo 4 to read the code string (SCN coding) of my EGS52 control unit.
Codestring (in decimal, Vediamo use this format):
098 103 052 055 010 002 000 002 000 000 006 005 003 004 000 002 001 001 000 000 000 001 000 002 000 002 000 000 027 004 132 013 232 003 232 003 198 007 029 000 024 051
Codestring (in hex):
62 67 34 37 0A 02 00 02 00 00 06 05 03 04 00 02 01 01 00 00 00 01 00 02 00 02 00 00 1B 04 84 0D E8 03 E8 03 C6 07 1D 00 18 33
Perhaps someone could help me adjust the byte string for the differential gear ratio 3.67 and for 3.27, both, and output this for me?
