2004 E500 Brake Failure!!
I would think that the backup syste should be adequate enough that it would not require extreme force to operate. I can understand extra force, but this seems very unusual. And, my personal opinion is that it is the dealers fault for not bleeding the brakes properly. We wouldn't expect total brake failure in a Hyundai, so we sure shouldn't expect it in our expensive MB's.
And what is even more scary is that it happened so suddenly. Something like this should be progressive, as would be in a conventional braking system. SBC was too much, too soon.
See how the dealer responds, but I would get in touch with an attorney. I'm sure that neither the dealer nor MB is going to want to refund your money or replace your car without a fight. They probably would consider that an admission of guilt.
Good luck!
Good luck!
fazooley
fazooley
If the pump failed totally then why wasn't it caught when it was in for the recall? Why would a pump fail totally with a relatively few applications while German taxis go into the 100's of thousands of brake applications?
There is something fishy going on here. Did they change your brake fluid or not? What did the recall service order say on your recall?
Did you open the hood and look at the SBC controller after you had the incident? Was there any brake fluid on the ground after the car was removed?
I certainly would find out what's going on before I started threatening lawsuits.
fazooley
fazooley
fazooley
Any comment on why the completely independent back up system failed too?
A friend of mine had the same problem with his '03 E240. They changed some parts and three weeks later it happened again. He demanded a new car as he had no confidence in any further repair work. None of his family members dared to drive it again. After 1 month MB agreed to give him a new one. He had the same opinion as you that other things may faulty but once it affects the safety of the passengers then the gloves come off.
Fight hard on this one.
Preventative medicine is always better than (attempts at) curative medicine.
Back up system works and i know some crazy dudes that tested it on side street- just to see how it works. They indicated that back up works and requires a lot of pressure on the pedal and it is very hard to modulate and causes lock up of the wheels.
I think some of you should try to drive a car without power brakes to know that you have press a lot harder than normally.
Glad you were able to manuveur out of harms way....
Whats worse is that I am probably going to be with out my car for the new year if I have to take it in tommorrow.
BTW, how many miles do you have on your car?
Keep us posted Frank...
greetingz,
His turned out to be air seeping into the front calipers and it was found to disable the entire system due to air blocks or something similair. Audi didn't do a recall apparantly and the problem manifested itself several more times in other peoples cars untill they had such a percentage that a generall recall was initiated, I don't know the percentages but when you consider the S4 is made in limited numbers you get the picture.
Fazooley
I was having all sorts of trouble with my SBC system and hydraulic braking system on my '03 W211. Here's a little refresher thread:
SBC brake problem
The dealer had my car for 9 straight weeks the third time it was in the shop for brake trouble. MBUSA had to come to my rescue. Between MBUSA and the dealer, they got me out of that Lemon-ridden '03 and into an '04 which has been perfect so far.
At the time, I was informed by the Regional SPOM (Service Parts and Operations Manager) that the vendor making the hydraulic brake pumps for the E-class was not sealing them properly. Mercedes apparently had to stop production and send all the brake pumps back to the vendor for proper sealing and correction of the manufacturing mistake.
Perhaps someone can update me, but I am not aware of any SBC recall that specifically involves hydraulic pump failure. The latest recall I believe addressed software related to the SBC system.
The reason I bring this up is because it sounds like you had complete hyraulic pump failure. You had no braking power, not even the "back up" safety system (which, of course, is hydraulic). No hydraulics = no brakes. Regardless of SBC function.
My "squeaky" annoying brakes were due to leaky hydraulic pumps. Heck, I had my pump replaced TWICE, and it still wasn't perfect. The first time the car was serviced for the poor control and squeaking, they found air in the lines. It makes perfect sense. The hydraulic system was compromised (likely at the pump), allowing air entrainment and poor pedal/braking control.
You said the dealer needed to replace your hydraulic pump. It sounds like your pump just totally blew and lost all pressure leaving you out in the cold with no brakes.
Good luck and hang in there.
Cheers
The squeaky sound was related to the hydraulic pump. It didn't squeak all the time, but when it did, the pedal became soft and mushy. It was very difficult to smoothly control the brakes.
now in limp mode and can't drive it and spent a lot of money on it and can't afford a nuther car and cant afford to miss work dont have a clue wat to do it just doesn't seem justified thay can get away with Mass producing a car that is so dangerous
Last edited by Dwayneruark2; Jul 8, 2023 at 08:41 AM. Reason: Car in limp mode don't no what to do with it spent a lot of money on it
