Cheap Fix for Front License Bumper Holes
As lamented elsewhere, all ED Mercedes have the front bumper drilled for the license plate. I don't know why they mount it on the face of the bumper, rather than using an L bracket and mount to a bottom surface of the bumper.
Anyway, the car had unwanted holes. I found very small nylon plugs at Home Depot and used two coats of touch-up paint.
Here's the result.
They also had small chrome-plated plugs that would probably look OK too.
Here's the result.
Me:04 E320 Pewter:Wife:04 E320 White
Can I get the SKU number from Home Depot for what you used? Want to go do the same thing to mine immediately...looks much better.
Thanks Jeff
Thanks Jeff
I'll try to find the SKU. You can find a variety of these plugs in Depot's hardware/fastener aisle. They're in a specialty fastener cabinet with slide-out drawers.
1 Post
'08 AM Vantage V8 - '03 E500
Just out of curiosity, when you get an ED car, are the holes drilled for a standard US license plate? As I recall, the holes are different for EU plates, although that may have changed.
It would be interesting to know (no, I'm not calling for a survey or poll) how many US states (probably no Canadian provinces) don't require a front license plate. It might be useful information for M-B in deciding whether the should predrill ED front bumpers. If a major state like Florida doesn't require a front plate ....
http://www.flsenate.gov/statutes/ind...n%2006#0320.06
... that right there is an argument against a blanket drilling policy.
Unfortunately, a front plate is required for Germany. So, if you buy ED, the car will have a plate.
I spoke with the ED supervisor in Montvale, and there was no way around the bumpber being drilled. The bracket is US spec and had holes to accommodate the European plate as well as a US plate.
GGM
California requires one, but I have always been successful just asking the dealer not to install when buying a new car.
Jeff
Jeff
Did MB convince the German government to create plates that fit a US template?
P.S. How exactly does one remote that ugly black front plate mount?
04 E320 4 Matic, 95 Audi S6, 99 Carrera 4 Cabrio, 12 Fiat 500 Sport, 00 BMW R1200C 10, BMW R1200R
Originally Posted by pa28pilot
So what's the deal with the tourist delivery plates. I checked, and the holes match up with my US plates. I know the regular EU plates are much longer than the ones that I received in Germany.
Steve
DIY "L" bracket for mounting front plate...
I had the same question and fabricated a suitable "L" bracket from a 1 1/4" aluminum angle made from 1/8" thick stock. I used a 1/4 inch thick backing plate with two 6mm threaded holes on the backside of the bumper cover. I had to remove the bumper to do the install but at least I don't have to repaint the bumper if I ever move to a State that does not require the front plate.
SL500 E320 ML350
![wall](https://mbworld.org/forums/images/smilies/banghead.gif)
Even if you are not handy, you can buy a bracket like the one showed in the photo 2 posts higher than this one.
The brackets are made for SAAB's and Volvos. They both have the 2 holes for the license plate. However, you do need to drill 2 holes to mount on the bumper. Those two holes do not have to be precise since only a screw has to fit, not a screw and a license plate.
For the Volvo one, it is aftermarket and can be found on http://www.ipdusa.com . It is called something like a trunk closer. Later, you can take it off and place it under the rear bumper so that you can close the trunk without making dust prints on your car's paint.
The SAAB one is OEM. See the SAAB dealer or see a photo of it on http://www.saabusa.com > owners (top right) > accessories catalog
An easy way to see a picture is to look at http://www.540i6.com and click "trunk handle" on the left near the top. This is the fastest way and requires less searching than looking through the Volvo IPD or Saab USA websites.
License plate trunk handles probably won't fit very well
The brackets you reference are probably not suitable for the front bumper on the W211. What's not apparent on the photo above is that the top side of the bracket needs to be trimmed to the shape of the mesh grille. Also, the trunk handle brackets are probably one inch or less. If you don't use a 1 1/4" bracket you will need some spacers between the black plastic MB plate bracket and the angle bracket. Since the plastic bracket needs to be positioned on the bumper before you put the angle bracket in place, it will be very difficult to fit the spacers.
