E-Class (W211) 2003-2009
Passenger Seatbelt Warning Light
Old Jan 20, 2005 | 05:53 PM
petesE320's Avatar
2005 E320 4-Matic
Hey everyone, quick question. I know that the '05 E class has a new feature now that reminds you to buckle your seat belt, but every once in a while it comes when I have mine buckled, and there is nothing in the passenger seat. Any one experience this or have any solutions?
Old Jan 20, 2005 | 06:09 PM
Barry45RPM's Avatar
2015 ML 350
Is anything on the passenger seat? Its got a sensor in the seat.
Old Jan 20, 2005 | 06:21 PM
petesE320's Avatar
2005 E320 4-Matic
No, nothing there, nothing had been there. I understand if a heavy box or a large package had been there, it may trip the sensor.
Old Jan 20, 2005 | 06:45 PM
yahooe500's Avatar
2005 E500 Silver/Charcoal
warning light
I have a similar problem. After passenger leaves car, light will stay on. I believe its too sensitive also, anything I lay on passenger seat will set it off. I need to engage the passenger seat belt to turn it off..I will take it in to service.
Old Jan 20, 2005 | 07:04 PM
tjkaz's Avatar
2011 E550
The passenger seat has a very sensative sensor in it. Comes on most of the time with my briefcase on it. Sometimes even comes on if I'm leaning my hand on the seat.
I asked the folks at the dealership of the sensativity could be adjusted. They said that they could not adjust the sensativity. Some on this board have posted that the dealer could disable it, but I seriously doubt that they would do that and risk any liability.
Good luck, and post anything you find out to this thread as a number of folks have brought this up.
Tom
Old Jan 21, 2005 | 12:29 AM
lorinserbenz's Avatar
none
My 05 E320's seat chime was beeping with nothing on the seat. I went to my dealer told my service advisor how to turn it off (info from this board) and he did. My dealer said there is weight limit adjustment...
Old Jan 21, 2005 | 02:23 AM
Ervin TBH's Avatar
Mine does it too and it is more likely to occur on cold days. I haven't been to the dealer about it yet.
Old Jan 21, 2005 | 12:38 PM
jago1244's Avatar
2016 G63 ; 981 boxster GTS
happened to me last nite. cold, and yes i had put my coat on the front seat. also, looks like it reruns the beeping cycle once you get down below the 'door-locking' speed and go back over it.
j.
Old Jan 21, 2005 | 05:10 PM
jameson75's Avatar
2005 E500 / 1993 MR2 Turbo
Had the same problem. I posted a thread about it. The seatbelt light and chime would come on when the passenger got out of the seat and would not go off. The airbag off light comes on but the seatbelt light and chime does not go away. Took it to the dealer and they said that the sensor needed to be adjusted, took no more than an hour or so to do.
Old Jan 22, 2005 | 09:24 AM
garyr6273's Avatar
05 E320 Pewter/Char COMAND/DVD Nav/Sirius
Hi there, new memeber here and new E-class owner. My 05 does the same thing. I have noticed that If you wait until you have put the car in drive before you sit your item in the seat, it seems to keep it from beeping. I did bring this up to my dealer (HBL in Tysons Corner, VA) and was told by my service advisor that was the design of the sensor, and there was NOTHING to be done about it. Will have to search the threads for the solution. I knew that MB wouldn't let Toyota and the other manufacturers best them on something so simple, I had a 04 Solara that only turned the airbag on if the item in the seat was heavier than 20 lbs.
Great to find this forum, makes being an MB owner so much easier!
