E-Class (W211) 2003-2009
Ipod 2004
Old Feb 17, 2005 | 12:52 AM
tgio's Avatar
e500 2004
Question Ipod 2004
I have new 2004 E500 and wonder if new Ipod system can be installed by dealer? MB web says 2005 and newer? Any thoughts? Thanks
Old Feb 18, 2005 | 12:05 AM
klpete's Avatar
I'm with you
I have a 2004 E320 and am anxiously waiting to see. It will move my iPod enhanced life one step higher!
Old Feb 18, 2005 | 12:46 PM
hoffyvortex's Avatar
2005 E500
When i was at MacWorld in January, they had a demonstration of the ipod kit in two cars. I spoke with someone from MB and they said it would most likely work (but not guaranteed) in 2004 E class. They were handing out brochures and the literature also said something to that affect.
Old Feb 18, 2005 | 07:06 PM
Mirage's Avatar
2004 Mercedes Benz E500, 1997 SL500 40th Anniversary Edition
If you look in your glove box (04'E500) you eill see a jack that accepts a male lead, all you would need is a double male cable to fit in your iPod and connect to the female lead in the glove box and you will be able listen to it.You must hit the AUX soft key on the COMMAND console for the connection to be made.
I use it all the time,it works great! You are just limited to using the volume control and cannot change songs from the steering wheel, this must be done manually thru the iPOD.I hear MB may change all that tho with some sort of upgrade by the summer or early fall, not sure if it will be hardware or software or a combo of both.
Have fun!
Old Feb 18, 2005 | 09:32 PM
tgio's Avatar
e500 2004
thanks!
Old Feb 18, 2005 | 11:20 PM
BklynBenz's Avatar
CL500
https://mbworld.org/forums/showthrea...awiner+dension
