Bulletins 207 coupe & 212 sedan
LI42.10-P-063149 JAN16 218.391 (cls500 4matic) rear
LI42.10-P-063150 front
LI42.10-P-063151 JAN16 – 212.091 (e500 4matic) rear
LI42.10-P-063152 front
LI42.10-P-063153 JAN16 – 212/218 (sport 951) rear
LI42.10-P-063154 front
LI42.10-P-063156 JAN16 – 212/218 w/brake dimensions 300x22 mm rear
LI42.10-P-063155 JAN16 – 212 w/brake dimensions 344x32 mm front
LI42.10-P-063157 JAN16 – 212 w/brake dimensions 320x24 mm rear
Would any of the TSB's you mentioned above apply to a 2012 E550 4matic regarding the "Brake juddering/shuddering felt when braking, replace linings & discs"?
LI54.10-P-064674 AUG16 – 212, 218, 207, 204 with start/stop (B03) production 12/2011 to 3/2012. Engine does not start / selector sticks in “P” and/or fault messages on driver assistance system, replace prefuse box F32.
You gave me some advice some months back as regards my 2010 E350 tranny, i am back with thesame problem again. Transmission still do a automatic P' mode at a speed less than 6km each time i slow down. I did a tranny flush and tranny reset couple of times like you suggested. My Technician had to take the valve body out today and check the solenoids/valves. Same problem still persist.
what is the likely problem? what do you suggest.
Best regards
P.S error codes is never stored on the system memory
I purchased my CPO 2010 E350 coupe from a M-B dealer, but the owners manual was missing and I received no data card - only what the dealer listed on their used car sticker. The dealer ordered an owners manual for me, but I did not the full data card information.
I would appreciate it if you could check and PM me the data card for WDDKJ5GB0AF018626.
Thanks in advance.
Service Campaign 2016050009 SEPT16 – 2016-2017 207, 172, 231, 217 air scarf function may have been deactivated, dealer will check electrical connectors. Approximately 534 vehicles affected.\
LI08.30-P-064799 SEPT16 – 222, 212, 205 hybrid AC inoperative no hybrid functions active until next ignition cycle, engine control module or powertrain control unit must be updated to latest software. Replacing battery does not remedy problem. 222 OK since 5/5/14/16 (VIN A277932), 212 5/31/15 (B214096), 205 5/14/16 (F400240).
Maybe you can help me with your wisdom. I want to change the factory springs to H & R s, however the sellers only list it for a E 350 and says it will not fit the E 250. My question is aren't both setups the same as far as the springs and shocks ? Thanks in advance.
However, I found on another site (True Delta) that there is an 08/29/14 TSB re: electrical and air conditind; "damaged ESC of driver circuitry side marker output."
Anyone know the TSB number because this sounds like my problem.
I do understand the parking lights system and have never turned them on. Lights stay on Auto, except very few times I actually turn on the headlights so I can activate the fog lights. Then I make sure switch is back on Auto.
Tru Delta said they got info from NHTSA and I went to their website for recalls and TSB's (AKA Manufacturer Communications). Couldn't find the TSB above.
Thanks again. At least I have it documented on work order that their is a complaint.
S-B-54.30/222 MAY09 - 212.056/072 up to VIN A016686 analog needles in the IC are not functioning for approximately one or two minutes after engine start typically occurs in cold temperatures. The IC software will be updated.
I have a question about the DTB P-B-54.70/218 bulletin. As far as I understood it was released on May of 2009. Does it mean that the cars produced later, 2013 E class for example, already have the latest software?
Erroneous warning happened to me 1-2 times when moving along the barrier. It also gave false warnings in rainy/snowy days. I took the car to the dealer and referenced to the service bulletin above. They said that they couldn't reproduce the error and that since my car is 2013, it already should have the latest software. Is that even true?
Thanks.
I think the service bulletin you posted said "to flash the SGR". The dealer said that SGR was for the distronic which my car doesn't have.
Any advise on how to ask them to check for the latest software is appreciated. I asked to check for Comand update once - they didn't.
LI82.95-P-065703 FEB17 – 213 remote start is not executed “Side window or sliding sunroof not fully closed”, update software to all four door control units.
LI82.85-P-065716 FEB17 – 213 with command NTG 5/5.5 (code 531) language of digital operator manual automatically changes, install newer version part # 2138276300 or successor.
LI68.40-P-065763 FEB17 – 213 non-AMG inside rear view mirror shakes or vibrates, install damper (see image below).
