Bulletins 207 coupe & 212 sedan
#301
Received 4,435 Likes
'71 Pinto
9/4/13
johnlk25 (03-07-2017)
#302
Now I have a question. I see that I have option code 258 "collison warning system with active brake interv fcw stop". I take that to mean that basically it has autonomous braking where the car will brake itself. I thought that all I had was where you just get the red light flashing and a warning beep. Are you telling me that the car will automatically apply the brakes?
#303
'71 Pinto
See capture.
johnlk25 (03-08-2017)
#304
Question about this post for brake shuddering
LI27.20-P-063110 JAN16 – 278 up to MY14 after a shift is performed under medium load a slight shudder is felt, low slip speed of torque converter lockup clutch allows engine firing order to be felt through driveline. Update software. Vehicles MY15 and newer have been produced with the software solution.
Brake juddering/shuddering felt when braking, replace linings & discs:
LI42.10-P-063149 JAN16 218.391 (cls500 4matic) rear
LI42.10-P-063150 front
LI42.10-P-063151 JAN16 – 212.091 (e550 4matic) rear
LI42.10-P-063152 front
LI42.10-P-063153 JAN16 – 212/218 (sport 951) rear
LI42.10-P-063154 front
LI42.10-P-063156 JAN16 – 212/218 w/brake dimensions 300x22 mm rear
LI42.10-P-063155 JAN16 – 212 w/brake dimensions 344x32 mm front
LI42.10-P-063157 JAN16 – 212 w/brake dimensions 320x24 mm rear
LI77.00-P-063147 JAN16 – 207 Cabrio chirping/rubbing type noise just before roof fully closes, seal in affected areas and Insert filler foam into seal channel (see photos).
#305
'71 Pinto
Is this saying there is an open recall or campaign on this? Or just a known issue? I ask because my car has the shuddering brakes issue; the brake disks were replaced about a year ago, and the issue has returned. So I'm facing the replacement of a second set of rear disks within one year.
iGeorge (03-12-2017)
#306
#307
'71 Pinto
Service Campaign 2017030011 MAR17 – 2005-2014 212, 207, 204, 203, 197, and 171 Takata defect decision, dealer will replace driver & front passenger airbag. Approximately 540 vehicles are involved.
#308
Hello Mr. Konigstiger, would you be able to provide my data card? My VIN is WDDHF5KB4EA996715 Thank You.
#309
'71 Pinto
“Mr. Konigstiger” ... fitting for an aristocrat
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
h2oaok (03-30-2017)
#310
2015 Triumph Thunderbird LT 2008 Dodge Ram Bighorn 2011 Mercedes Benz E550 Sedan
Mr Konigstiger...I just got a new to me 2011 E550 with only 18K miles. WDDHF7CB3BA421818 and today i just noticed that the passanger seat is not straight. It is calked of to the left a bit. Everything works as far as adjusting the seat. I'ts not straight like the driver side. The track looks like it takes a slight different angle than the drivers side... Wierd!!
Was there ever any bulletin about this? Thank you for all you do for everybody!
#311
'71 Pinto
Reference LI91.10-P-054143 “adjustment is biased to one side which bends the seat frame”.
LindseyDA (04-22-2017)
#312
#313
'71 Pinto
Recall Campaign 2017030015 APR17 - 2006 through 2016 117, 164, 166, 190, 204, 205, 207, 211, 212, 218, 221, 222, 231, 253, and 463 vehicles that received a control module coding update while at dealer between December 3, 2016 and December 5, 2016 might not function as intended dealer will update the affected control modules.
#314
Hi Mr. Konigstiger...
My Tranny started acting up today. I took off and it didnt want to shift. stayed in 3rd. After a mile or so it starte working fine. Got out of my car to go to the store...got back in and it did the same thing for a mile or so then started to shift normally.
Also first thing in the morning I start the car put it in D, step on the gas... and there's a little jerk then all is good. It doesnt happen but in the morning when the motor tranny is stone cold.
Can you please give me your opinion? 2011 E550 with only 21,000 miles...
#315
'71 Pinto
LindseyDA (04-27-2017)
#317
'71 Pinto
Certainly.
#319
12 e5504m see attachments for current part #s compare to invoice parts #(s) installed. Not recall or service campaign but rather MB bulletins covered under factory warranty (aside from 1 year/12,000 mile MB brake warranty), dependent on wear in your situation you "may" be able to successfully argue no cost disc/pad replacement referencing MBUSA 12 month/unlimited part warranty if within this period - dealer may refuse, contact MB 800-367-6372.
#320
![](https://mbworld.org/forums/images/ranks/veteran_marine_corp.png)
W212 E-class, W211 E-class, F10 5-Series
Is that saying that Collision Prevention Assist is a sub function of Distronic Plus? I don't have option code 258 on my data card, but I have codes 233, 266, 271, and 300 (which all reference some form of autonomous driving/braking). My CPA doesn't seem to be working, as I never get a warning beep or anything, no matter how close I get to the car behind me (unlike other cars I have driven, I get the warning beeps). I don't even have the CPA menu in the dash options. The dealer says it is part of Distrionic and it's "working normal". How do they know it's working fine, if the thing doesn't even work.
#321
Good afternoon,
Can I please get one for VIN: WDDHF8JB2DA717313
I was just gifted this car but have no idea what all it has.
Thank you!
Thank you!
#322
'71 Pinto
10/10/12
#323
'71 Pinto
Recall campaign 2017040007 May17 – 2017 207 propellant mix ratio in pelvic airbag igniter might not meet specifications, dealer will replace airbag. Approximately 255 vehicles affected.
#325
'71 Pinto
LI54.65-P-066284 MAY17 – Vehicles with reversing camera (code 218) or 360 camera (501), see attachment.
