Sponsored by: CARiD
LED Daytime Driving Lights
Old Sep 1, 2009 | 12:23 PM
blueC230K's Avatar
2002 W210 M112 | 2021 X247 M270 | 2015 Audi SQ5 | 2015 VW Golf R
Question LED Daytime Driving Lights
Does any of you guys know if the DRL--LED turns on at night too? I swear I saw an E350 sedan with both headlights and LEDs on one night. I have an E350 coupe. I tried this on both auto and manual light mode but no luck. Yes, I have enable DRL on the settings already. Is this some sort of re-programming that has to be done through star diagnosis? Any takers? Thanks.
Old Sep 1, 2009 | 05:04 PM
petee1997's Avatar
...24 GLE53
In Canada,where running lights are compulsory,they are reduced to 10% power when the head lights are deployed.
Old Sep 9, 2009 | 01:23 PM
blueC230K's Avatar
180 views and no one knows? any techs here?
Old Sep 9, 2009 | 02:47 PM
blueC230K's Avatar
Found this from Konigstiger:
Service Campaign 2009070001 JUL09 to properly re-calibrate daytime running lamp operation, a software calibration number (SCN) update must be installed
Thank ME!
Old Sep 26, 2009 | 09:14 AM
J718's Avatar
2010 e coupe
"Service Campaign 2009070001 JUL09 to properly re-calibrate daytime running lamp operation, a software calibration number (SCN) update must be installed"
hey bluec230k,
what does this mean ? and where do i go to get this done? i want my DRL at night.
Old Sep 26, 2009 | 03:48 PM
konigstiger's Avatar
'71 Pinto
Have your dealer check VMI to see if VIN is included in this campaign if so the dealer will perform work.
Old Sep 27, 2009 | 10:37 PM
mallard's Avatar
2012 CL550
The LED's on my car are on when the headlights are on but are much dimmer than during the day.
Old Sep 27, 2009 | 11:34 PM
Kar don's Avatar
Mercedes-Benz
Thank ME!
Whats a W207? The new E-coupe is a C207.
Old Sep 29, 2009 | 12:01 AM
Dema's Avatar
i535
I guess so, I saw S350 today and it had LED running on at night. However E350 which I drove didn't have LED. Perhaps it is an option.
Old Sep 29, 2009 | 10:52 AM
blueC230K's Avatar
The LED is a P2 option in the U.S. for the 2010 E-class. The brightness is reduced for both sedan (glow at 10%) and coupe (glow at 50%) in the dark.
Old Oct 27, 2011 | 07:56 PM
PHML's Avatar
2011 GLK350 P1, Multi-media & AMG Pkg; 2010 E350 w/ prem 2; 2018 4Runner SR5 Prem. 4x4
Sorry...i know this is an old thread, but....
Under the Convenience feature, I enabled everything under the Lighting menu. My DRL LED (hockey stick) turns ON during the day. At night, everything (HIDs, inner projectors, side markers, and DRL LED) turns ON. My light switch is at "O".
I notice that with those settings mentioned above, and I turn my light switch to "A", the DRL LED turns ON during the day, but it turns OFF at night...only the HIDs, inner projectors, and side markers turn ON.
Hope this helps.
Old Oct 28, 2011 | 01:33 AM
axhoaxho's Avatar
I have a 2012 E350 Coupe with P2 Package.
Yes, when my headlights are turned-ON at night, the DRL LEDs will also remain ON (but dimmed from the daytime brightness -- I guess Mercedes does not want them to blind the drivers of the cars ahead.)
(I cannot confirm this, yet I have heard from some C207 owners that without the P2 package, the DRL LEDs will not remain ON when the headlights are turned-ON... Can any other owners confirm this? Thanks.)
Regards,
Old Sep 3, 2014 | 09:44 AM
dincyp's Avatar
Mercedes E220 CDI AMG
E-Class (W207)
My E class coupe 2011 model the hockey lights turn off automatically when head lights turn on. I also saw other cars in the road same model as mine and the head lights and running lights are both on. Is there any special programming with STAR program for that. Does somebody knows how. I called MB dealer but they don't have idea. They replied that day lights must be off at night but I want them on.
Old Sep 3, 2014 | 10:31 AM
Russ103's Avatar
2012 E-350
Holy zombie thread!
Old Sep 3, 2014 | 10:44 AM
Arrie's Avatar
The DRLs should be ON with the head lights but with much lower intensity. They are full power at daytime when head lights are OFF.
Old Sep 3, 2014 | 02:15 PM
dincyp's Avatar
Thanks Arrie for your prompt reply. What you describe is what I wanted my car do but unfortunately as soon as the headlights turn on the day lights turn of immediately . I imported the car from UK and as I read on some forums there is a rule in the UK low that not allow the day lights running on night. So my question is : does the running lights can be programmed with a computer to run on night or I must change a hardware or something else . Our dealer here in Cyprus has no idea . My model is E220 Blue Efficiency cdi AMG a and year of first registration is 11/2011
Old Sep 3, 2014 | 03:12 PM
Arrie's Avatar
I'm not sure but somehow I remember that the DRL has two set points for intensity. One is 100% at daytime and then the lights take the dimmed set point when head lights come on. I remember reading somewhere that this dimmed set point is 30% and that set point is adjustable thru the Star system.
If it operates like this it could be that this dimmed set point in your car is just set to 0% meaning no light at all when head lights are on. Could be as simple as just changing this 0% to something else to make the lights burn with the head lights.
But as I said I'm not sure of this. Just remembering reading about this somewhere.
Old Sep 4, 2014 | 01:22 AM
dincyp's Avatar
Thanks Arrie
Do you remember the forum you read that information ? Can you find this topic for me? Does someone else knows whereo find such information ? You kind assistance will b much appreciated
