LATimes test the 2010 E550 coup2 .
Read on :
Mercedes' 2010 E550 Coupe wins the E-class beauty contest
Dan Neil
September 25, 2009
Is the 2010 Mercedes E550 Coupe pretty?
This is no trivial matter.
After all, why would you buy an E Coupe when for about the same money you could get Mercedes' new E Sedan?
The mid-size four-door Benz is the standard by which all Mercedeses are measured. It's the company's bestselling model worldwide and the unimpeachable choice for every Beverly Hills tennis pro and real estate agent who ever lived. The E Sedan is bigger, more practical, more richly equipped. It's a car every bit as tightly nailed together, offering performance nearly equal to that of the sports-minded E Coupe.
Only one reason: The E Sedan is beastly looking.
In my review of June 12, I said the sedan was "very proper and Swabian and gloriously unartistic." In the months since, my opinion has only soured. I hate the way the car slumps at the head like a pole-axed buffalo. I loathe the over-shaved, winnowed taper around the grille. I detest the graceless quadrangle of windows on the sides. I gag on the exaggerated accent lines on the fuselage that don't visually intersect with anything in particular.
It's a terrific machine, but really, the E Sedan's homeliness has a kind of malign ambition about it.
Meanwhile, the E Coupe, the replacement for the long-lived CLK Coupe, is lovely. The grille -- with two horizontal bars supporting a softball-sized Mercedes emblem -- looks tougher, more masculine and declarative. The black-mesh intakes in the lower bumper are deeper and more aggressive. On the E Coupe, the accent lines actually give the shape some visual velocity, converging like metal contrails at the rear of the car with the deco-like fender flares. The roofline arches exquisitely over a pillarless canopy (that is, there's no "B" pillar roof support). Low, wide and rakish, the E Coupe design has an organized, coherent energy about it, a godly brow to the E Sedan's low forehead. And the impression of sleekness is borne out by physics. Mercedes claims this is the most aerodynamically efficient series production car in the world.
By the way, those fender flares, according to Mercedes propaganda, recall the company's Ponton ("pontoon") cars of the 1950s. I'll take Mercedes Trivia for $1,000, Alex.
And now for some factoids: The E Coupe, like its sedan sibling, comes in two flavors: E350 Coupe, with a 3.5-liter, 268-horsepower V-6, good for a 0-60-mph dash of 6.2 seconds; or E550 Coupe, with a 5.5-liter, 382-hp V-8 that will accelerate to 60 mph in a damn respectable five seconds flat. Like the sedan twins, both coupes have a seven-speed automatic transmission with manual-shift buttons on the steering wheel. The E550 Coupe gets slightly bigger brakes, wheels and tires as well as adaptive suspension (Mercedes holds back the air suspension found on the E Sedan).
Not surprisingly, the E350 Coupe gets better fuel economy: 17/26 mpg, city/highway, to the E550 Coupe's 15/23 mpg. The V-8-powered car is base-priced at $54,650, while the V-6 car starts at $48,050 (both cars are about $2,000 less than the comparable E Sedans).
Having digested this number salad, you could be forgiven for thinking that the
E Coupe is, in fact, a two-door version of the E Sedan. But that would be too easy, wouldn't it? Despite the nomenclature and the many similar styling cues, the
E Coupe is actually based on the smaller C-class chassis.
That's not a bad thing: What you have here is a compact frame stuffed with the guts of a big performance sedan. This is a taut, ferocious little luxury tourer, with excellent brakes, high-strung steering and engine torque that comes on like Man o' War in the final furlong: 391 pound-feet of torque between about 2,500 and 5,000 rpm. The E550 Coupe weighs 251 pounds less than the sedan. Combined with the highly dexterous seven-speed gearbox, the E550 Coupe will pass just about anything on the road. Simply kick down three gears, pull out the whip and start wailing.
At these moments of throttle-tromping honk, the E Coupe's exhaust note is big, brassy, an ornery and operatic cackle. Beautiful. But take your boot out of the accelerator, and everything goes quiet.
A benefit of the low aero drag is, of course, low wind noise. At relaxed speeds, the E Coupe's cabin ambience conjures a plummy, hushed purr.
How's it feel? The steering wheel is like a stitched-leather barbell. The tactile feedback through the seat and floor is one of heavily damped, cold steel structure attenuated through the fine-grain leather. The E Coupe's interior gets a dose of high-end upholstery that is usually associated with Mercedes' premium AMG-edition models.
This is a four-seat car -- that is, two bucket seats in back -- and while access to the rear is good and headroom under the low roof is surprisingly ample, the rear seat space is for occasional use only. That's another reason to prefer the coupe to the larger sedan. It's a private reserve. Between its compact size and forward-cabin focus, I found the E Coupe to be as intimate as lacy underthings.
Loaded with new standard features -- pelvic and knee air bags, driver drowsiness sensor, panoramic roof -- and kitted with ample Mercedes luxury, the E Coupe is fast, athletic, beguiling. For anybody weighing the choice between four doors and two, it puts a gorgeous thumb on the scales in the coupe's favor.
dan.neil@latimes.com Copyright © 2009, The Los Angeles Times
Dan Neil
September 25, 2009
Porsche 991S, Cayenne S, 1972 BMW 3.0CS E9 Coupe
Here's the link to the article: http://www.latimes.com/business/la-f...7378935.column
For anyone who says Neil doesn't like MBs, that's not true. He's written many positive articles. He's fanatic over the Black Series.
But, like many auto critics, he's not keen on the W212 design. (and neither is Jeremy Clarkson, fwiw.) People have barked about it here (both positive and negative) and on just about every car forum (even BMW forums, etc..) The exterior design is controversial. Eventually the controversy will fade away as the car becomes mainstream.
"In my review of June 12, I said the sedan was "very proper and Swabian and gloriously unartistic." In the months since, my opinion has only soured. I hate the way the car slumps at the head like a pole-axed buffalo. I loathe the over-shaved, winnowed taper around the grille. I detest the graceless quadrangle of windows on the sides. I gag on the exaggerated accent lines on the fuselage that don't visually intersect with anything in particular. It's a terrific machine, but really, the E Sedan's homeliness has a kind of malign ambition about it."
I'm glad to see he wrote a positive article about the coupe. That's great.
Received 1,028 Likes
2010 E350 4Matic
Read on :
Dan Neil
September 25, 2009
Dan Neil
September 25, 2009
Oh-Oh This guy must be another jealous W211 owner.
I agree with him that the design comes together much better on the coupe, but it's still a $50k C-Class
12 CLS550, 09 CLS550, 04Cooper,10 Cooper S
Everything else about it is not C Class.
2010 E350 4Matic
Now come on. It that a negative that it rides on a c class chasis. If you want to make a coupe shorter than it's sedan counter part why not use a already existing shorter chasis (that is new) in the model line up and inturn cost low.
call it whatever. it is a step in the right drirection in design from where the CLK was and more toward the CLK was in the 90's.
The car over all has more upscale feel and features than the C class. Hence they have to badge it as something different so you cant make the same comment you made earlier that it is a $50K c-class followed by something like why would anyone pay over $50K for a "C" class.
Honestly, i don't think MB's alphabet soup had gotten that out of control to drop the clk nomenclature.
Besides, there was a C coupe (& still is in europe) and even though I owned one a while ago it was an awful cheap mess of things. in retrospect, i should have bought a golf GTI instead
2009 SL550 Roadster Diamond White, 2008 CLK550 Coupe Obsidian Black
Ya, E coupe is a big step up from CLK. CLK wasn't a good name cause if kind of interfered with the CL name, but then again, the CL will be leaving soon as well for the S coupe.
Porsche Macan S SportDesign / Ex M-B's: 11 & 10 & 06 E350's, 02 S500
Ouch:
"Only one reason: The E Sedan is beastly looking.
I agree with him of course, but I actually like the Sedan more than the Coupe, lol. I just can't get into the proportions of the Coupe. Although it is more graceful than the Sedan, IMO it just looks even more jumbled and awkward.
Also, the interior is clearly that of a C-Class (very bad thing as the W204 has an embarrassing inside) more-so than an E-Class IMO, although it is still much nicer than the C's.
Every time I refer to the E-Coupe, I naturally want to say "C-Coupe", not even trying to make myself say it either.
