Sponsored by: CARiD
Headlamp light switch
Old Oct 29, 2009 | 01:36 PM
siraseranant's Avatar
slk350
Good Afternoon Everyone:
I was wondering if the entire headlamp light switch of the new E class illuminate or just the actual switch itself. For some reason these symbols for P, A, etc. are not lit up at night on my vehicle.
Old Oct 29, 2009 | 02:17 PM
MartinG's Avatar
2010 E550, 2009 SL550
Only the switch knob itself is lighted. The escutcheon is not and this is something I can't understand. The escutcheon should be lit so you can see in what position the switch is set. My wife's SL is unlit too.
Old Oct 29, 2009 | 02:49 PM
slk350
Thank you for your reply. That is strange. My old SLK's did also all light up. I guess, MB wants us to set it on "A" and forget it.
Old Oct 30, 2009 | 01:13 PM
Steel.Grey.MB's Avatar
2010 E550
I'll have to admit the headlight switch on the new e is quite confusing. I set it to "A" and forget it.
Old Oct 30, 2009 | 02:55 PM
MartinG's Avatar
If you leave it on "A", when you let someone park the car for you, often they think they have to turn the lights off. When you get the car back, you assume it's still on "A" and you're driving without lights. Always check the position afterwards.
Old Oct 30, 2009 | 03:00 PM
Dartman's Avatar
CL600 (sold) E550 Sedan
As the saying goes, "been there done that". Good advice....
Old Nov 1, 2009 | 08:34 AM
mm9351's Avatar
2020 GLE450 polar white AMG pkg.
The headlamp switch only illuminates on the center of the knob. Although the outer ring does not illuminate, the ambient illumination running along the dash trim just above does a good job of illuminating the ring. Try setting the ambient illumination to a higher setting, and that will do the trick.
Old Nov 1, 2009 | 08:48 AM
Diesel Benz's Avatar
But it has been the same for several models, probably the "A" setting being the only difference from really old cars and the A has been there at least from the W211, likely earlier.
