Sponsored by: CARiD
Resting Tire pressure gauge
Old Oct 29, 2009 | 09:24 PM
pro3g's Avatar
w212
Anyone know of a work around to get the tire pressure light off. The problem is with aftermarket wheels the pressure you need in the wheels is different so it triggers the sensor because it is a different setting then the stock wheels. anyone know a way to fix this.
Old Oct 30, 2009 | 05:13 PM
silberrosa's Avatar
Follow the calibration procedure as mentioned in the Operator Manual. You essentially set the tires to the desired pressure, and you can set the system to "learn" the new values.
Old Oct 30, 2009 | 06:18 PM
aeggroup's Avatar
2025 Range Rover, 2022 BMW M850 , 2017 MB E400 Coupe
Here is the link which says how to do it :
http://www4.mercedes-benz.com/manual...html#d13e62896
