Break-in Period Advice
I am taking delivery of a new E550 (black on black, P2, sport) next week!
This is my first brand new car, so I was wondering if anyone has any advice on the Dos and Don'ts during the break-in period. Like what is considered the "break-in" period... 1,000mi, 1,500mi, 2,000mi
I know to be "gentle" and not to drive at a constant speed for to long to work through all the gears evenly. Also, from what I have read, I should not exceed 50% throttle for the first 1,000 mi, and then gradually work my way up to 100% over the next 500 mi or so, but I really have no clue.
I am picking up direct from the factory and will drive about 200 miles to get back home on day 1.
Any advice is appreciated.
I will be sure to post pictures as soon as possible.Thanks!
actually to tell you the truth what i really wanted was to do a oil change at 1000kms just for the hell of it. the service manager told me i would be wasting my money and to go drive it like its meant to. my car came with a manual, i can imagine yours did aswell
None of our 3 MB's have ever required an oil topoff between 7500-10k mile oil changes, and other than a bit of black diesel soot from the cdi every now and then, none of the cars have ever let out a wisp of smoke.
When I used to build engines, I used to see the effects of good and bad running in. Bores a bit glazed, bores very glazed, bores not glazed at all.
The manual is written in a non-scary way. No manufacturer wants to give you a complex procedure to follow - it's just not good PR.
If you follow the manual, you may do well and you might be fine. Let's have a look:
Or "flex the engine in the mid range, as you drive on a road that requires acceleration and deceleration". This is correct, and the high gas pressure in your cylinders as you accelerate will push the piston rings evenly into the bores (and the deceleration will bring the oil up for cleaning) and you will end up with a good seal.
Think - an E250 CDI will have a higher gas pressure at half throttle than an E200 CDI at full throttle (same engine innards). So if it's fine for one, then why not the other.
So, if you happened to interpret the instructions correctly, you will have good bores. But if you treat the car with velvet gloves, then you will have glazed bores. No problem - just slightly poorer power, economy and oil consumption. If one bore glazes more than the others, then smoothness will suffer too. Nothing to write home about - but there's no need for it.
When I was building race engines though, it was critical.
End of internet BS. Maybe if I showed you face to face, then the same advice would not be BS.
PS - people have argued about the Mototune advice. This advice is good - but applies to old fashioned honing. Modern car manufacturers use a slightly more cunning honing form, and so it is not so important to get this done in the first few miles - you have a little longer.
This is the exact reason I started this thread... To get everyone's past experiences and tips. The manual verbiage is very vague and can be interpreted many different ways.So, those of you who are reading this thread for the first time, please do not post "read the manual." No s**t!? I think we are all bright enough to understand that you should take the time to read through the important sections of the manual.
In my opinion, this forum is intended to go beyond what MB publishes and get real advice from people with real-world experience. I have learned a lot from everyone's posts here, and, like most of you, I take what I read with a grain of salt, because everyone's experiences are different. But that what makes it work... Knowledge sharing... Not just regurgitating what is written in the manual.
So, now that I am off my soap box, thank you again (everyone) for your contributions and to those of you who continue to contribute.
Cheers!
Imagine we rewrite the owners manual, to tell the owner what to do. I shall include some potential owner responses.
For the first thousand miles, the engine piston rings should be seated into the bores evenly. This is done by bursts of high gas pressure in the bores.
What?
Warm the engine up completely by driving it normally.
How do I know when the engine is warm - is it when the water needle is at the top? (No!) What is normal?
Give the car bursts of acceleration, and hold it in that gear as you let the car slow down.
I crashed because the new tyres had no grip / I went too fast and you told me to / the road was wet and I skidded off / there was a car in front and you didn't tell me to look out. I am going to sue you.
Avoid light throttle constant speed cruising.
I just spent $x,000 on a new MB and I can't go and see my brother who lives 500 miles away?
See the problem?
I just wanted to hear what other people's experiences are and hear their "advice." This is my very first new car and I will be driving it from mile 0, so I am new at this and just want to gather as much information as I can, internalize it, listen to what MB has to say, and make some educated decisions. I've never been one for only listening and following 1 source of information... But that's just me.
Thanks!
Norb, what exactly do you opine is BS?
As usual, the advice is to do bursts of full throttle at mid revs to get the rings to seal. But there is an explanation for no continuous high revs - overheating of the honing (I had never though of that).
http://www.ntnoa.org/enginebreakin.htm
