Does anyone know of any cool hacks for the new E class?
The only thing is that my voice command is not working, they say that this car never had it that functionality (command without nav), personally i dont mind as i can use Siri.
Yes, my warranty expired last year. When I spoke to the SM he said that my car never had this function and that the BT audio streaming didn't come standard until 2012; he thinks that the BT audio streaming is a by product of using the BT phone feature. I guess I should tell them that I hacked the system because I'll have to pay for the update anyway.
Spotify is working perfectly with the system!
2010 E550
Samsung Galaxy S4 phone
-End Call + # + 1: opens Engineering Mode
- HU Settings
- HU Parameter
(the following are the settings I put them in)
(1) BT contact plate: Not Installed
(2) LCT: Installed
(3) BT audio: On
(4) Audio Aux: Off (greyed out: not an option)
(5) Video Aux: Off
(6) Navi: installed
(7) BT: on
-back buttonx2
-pull command wheel down
- system reset
- reset - yes
- go to audio, then go to the audio tab again to bring up the drop down menu of audio options, select BT audio and activating audio device comes up, then the audio streaming screen
I have included screen shots of all the important steps (sorry for the poor quality but it was night time and the flash on my phone kept going off) Let me know if I need to clairfy ne thing.
It is in the instrument's menu.
Scroll to the Sett. menu with your left side arrows and then to Cluster menu and there is a selection for the "Permanent display" where you can select either speed or the temperature. I assume you now see speed..?
2. Insert cd into NAV system, etc.
So, would you say I need a newer cd or NAV system...any /all suggestions are welcome!
Thanks from a first timer!!!
I had an Audi in the past and it had a system that read the disk for the operation.
If your navi sometimes works and then sometimes gives those errors it could just be dirt issue in the disk player. Just like with any CD or DVD player you can get dust on the reader lens or the disk itself is dirty.
Check / clean the disk and if this does not help try cleaning the player. I don't know where the player is located but I used to clean my old CD players with a slot with a compresses air cleaner can. These are sold in computer stores and the can comes with a narrow tube that you can insert inside the player thru the slot. Spray air around inside the player and hopefully the problem is dust on the reader lens that the air will blow off.
http://www.ebay.com/itm/MERCEDES-Video-in-Motion-TV-Free-GL-ML-E-C-B-A-CLA-CLS-G-GLA-SLK-class-2011-2015-/261214932487?hash=item3cd19f8e07
- HU Settings
- HU Parameter
(2) LCT: Installed
(3) BT audio: On
(5) Video Aux: Off
(6) Navi: installed
(7) BT: on
-back buttonx2
- system reset
- reset - yes
do you know if this hack will work on 2007 e350 4matic
I have a 2010 E-350, BT Phone pairing works without any issue, but BT Audio doesn't connect with my iPhone 5S. I keep getting "Connection Unsuccessful" message. However, I can connect to a Samsung Galaxy S5.
I asked the MB dealer to upgrade car's firware and he said it is up to date.
Any help ?
I want to thank you for posting this great procedure and everyone who provided their great input on this subject! I gave it a try today with my iphone 5, now if I'm only traveling a short distance and don't need to keep my phone charged I can BT it and listen to my music uninterrupted. Thank you all so much!
I managed to enter the engineering mode with you instructions but could'nt do much to change my situation. My car I as e250 2010 w212 and comes with the unit show in the picture. I can pair my Phone (Samsung Galaxy Note 4) via BT, and use it for calls. But I can't play music from my Phone.
Apreciate your help in advance.
[IMG
7]Alright guys I'll do my best at this... (BT=Bluetooth)
- HU Settings
- HU Parameter
(2) LCT: Installed
(3) BT audio: On
(5) Video Aux: Off
(6) Navi: installed
(7) BT: on
-back buttonx2
- system reset
- reset - yes
- HU Settings
- HU Parameter
(2) LCT: Installed
(3) BT audio: On
(5) Video Aux: Off
(6) Navi: installed
(7) BT: on
-back buttonx2
- system reset
- reset - yes
Hi,
first time post, so apologies if this is incorrect in anyway. I am trying to activate BT streaming to my E class W212 (I think, at least). Following the instrcutions above and elsewhere on other threads, I get a totally different 'Engineering Mode' menu - see pic. I have had a good look around and cant find anything that may have the same effect. Any tips on how to get the same result from this menu would be greatly appreciated.
Cheers
