Non-HID headlight bulb change
Old 06-11-2010, 10:54 AM
kimf70's Avatar
07 G500
Originally Posted by crazygordon
Go figure, HID as an option on a Benz while standard on a Camry. I bought an aftermarket for my GL and installation was painless after I removed the wiring from the OEM bulbs. Nice and bright.
what system did you install? HID or PIAAs?
Old 06-11-2010, 11:55 AM
Taiwanese's Avatar
2003 C230
crazygordon,
After your HID install, did you get any error code or dash light come on?
Old 06-11-2010, 12:23 PM
crazygordon's Avatar
gl 350
Hi Taiwanese:
I installed HID, bought a slim ballast and "stuffed" into the projector light housing. A little nervous about "stuffing" the ballast but I will pay attention to the heat of the ballast. Read in some posts that the heat was not a problem.
I don't get an error codes, as there was a second in line device to take care of it. Relatively easy besides remove the original wire from the OEM bulb.
Old 06-11-2010, 12:50 PM
Taiwanese's Avatar
2003 C230
crazygordon,
Thanks for the quick reply. Which kit or what site did you get it from?
Old 06-11-2010, 02:01 PM
gl 350
I got the kit from HIDEXTRA.COM, I have a H7 bulb and ordered the slim ballast. They currently have a $20.00 coupon. COUPON CODE: loyaltysp-m
It's a generic Chinese brand but it works.
Old 06-18-2010, 08:47 PM
smelkony's Avatar
Great tip crazygordon, I just purchased these Slim Ballast 8000K H7 for $70 free shipping and I was able to install the passenger side and works perfectly without error messages, but I can’t get my "skinny" hands in the drivers side. The owner’s manual says to remove the screw for the wash reservoir and move it aside, that doesn’t help. Does anyone know when else to remove to access the bulb?
Old 06-18-2010, 11:44 PM
  #32
smelkony's Avatar
i just installed the drivers side finally (my arm is in pain). I drove about 100-200 feet and both lights turned off and i got the check low beam message in the dash. Do i have to get this cars ECU set to xenon=present like i had to do with my 2008 E350? Crazygordon, did yours work without getting the ECU programmed?
Old 06-19-2010, 08:03 AM
  #33
gl 350
Smelkony, did you get the additional harness required so the ECU does not indicate a light bulb out? My kit came with one these for each ballast; therefore I did not have to program the ECU and I don't get a light bulb out. Its some kind of load resistor that tricks the computer. It was included with my kit so if they forgot, you should get it from them, its included in the price. Good luck.
Old 06-19-2010, 01:00 PM
  #34
smelkony's Avatar
yes i installed both the slim ballasts and black rectangular boxes. is your car a 2010 E350 or is it the GL350?
Old 06-19-2010, 01:15 PM
  #35
gl 350
I have a 2010 GL 350 I am no where near my car otherwise I would look at set up and send you a picture. I can send it tomorrow afternoon if you need.
Old 06-21-2010, 11:17 PM
  #36
smelkony's Avatar
that would be great if you can. I also emailed the people at hidextra.com and they are doing to send me "capacitors" to install. Hopefully it's simple to install and will resolve my issue. Thanks
Old 06-22-2010, 08:13 AM
  #37
gl 350
Here you go a picture of the passenger side wire. The capacitors are plug and play, very easy. Good luck.
Attached Thumbnails Non-HID headlight bulb change-img00018-20100622-0752.jpg
Old 06-22-2010, 10:29 AM
  #38
smelkony's Avatar
Thanks. I don't have the smaller part on top, the girl at hidextra said it should arrive in 4-7 business days. I guess no driving at night for a week. Thanks again for taking the time to snap a pic, very helpful.
Old 07-08-2010, 12:44 AM
  #39
denisavu's Avatar
2010 GL450 E550W4
Any splicing involved in the conversion? Is the conversion plug-n-play?
Old 07-08-2010, 09:02 PM
  #40
gl 350
No splicing, all plug and play. Fairly easy after you remove the OEM bulb.
Old 12-04-2012, 09:59 PM
  #41
Georgediy's Avatar
2010 E350
I did the same thing by unintentionally removing the high beam bulb as I was reaching into the tight space - I installed it back in place. Now that I have access to the low beam headight assembly, I have a hard time removing it. I tried to turn it counterclockwise with either my left or right hand to no avail. It wiggles a little bit but I could not pull it out. Could you please share your techniqe with me? Thanks.
Old 12-04-2012, 10:05 PM
  #42
Georgediy's Avatar
2010 E350
Originally Posted by icelandicmax
changed out the light bulbs tonight. it was a b*tch to change them out, especially the driver's side one. will test them out on the road tomorrow. hope they're worth the bruises and scratches...
To icelandicmax, I have access to the driverside low beam headight assembly but I have a hard time removing it. I tried to turn it counterclockwise with either my left or right hand to no avail. It wiggles a little bit but I could not pull it out. Could you please share your technique with me? Thanks.
Old 12-04-2012, 10:11 PM
  #43
Georgediy's Avatar
2010 E350
Originally Posted by kimf70
I just changed out the lights to extreme whites.
It took me about 2 minutes to change out the bulbs. I was patting myself on the back until I realized I changed out the high-beams. damn...
Changing out the low-beam on the driver side is a BIACH! (definitely took more than 2 min.) I wear 8.5 gloves (snug). Ultimately, I got it in. Damn. It was a chore.
To kimf70, I did the same thing by unintentionally removing the high beam bulb as I was reaching into the tight space - I installed it back in place. Now that I have access to the low beam headight assembly, I have a hard time removing it. I tried to turn it counterclockwise with either my left or right hand to no avail. It wiggles a little bit but I could not pull it out. Could you please share your technique with me? Thanks.
Old 12-04-2012, 10:18 PM
  #44
Nuru's Avatar
S350 BT 4MATIC
Originally Posted by blackbullit
I ordered PIAA Extreme White bulbs as soon as my E550 (no P1 or P2) arrived. They dramatically improved nighttime visibility, as well as appearance of the car. As others have said, installation is painful but worth it! I also had to adjust headlight aim. MB factory had the headlights aimed at the ground!?!?!
I would like to also install PIAA EW bulbs in the running lights (stock are yellow). Anyone know the bulb type?
Actually that is probably either your state or the DOT regs for the pointing versus MB. In my area they seem way, way, to low. And each dealer says they cannot by law aim them higher. Strange to me as I am seeing people with hugely bright headlights all the time out here. I am going retrofit HID headlights (hardest/$$) or PIAA bulbs (easiest/Less $), or trade in for a used 2012 with P2 (most $$$/better mpg+).
Old 12-05-2012, 01:26 AM
  #45
BlackB-Wald's Avatar
E350 4matic, Porsche Cayenne S
Does anyone in here that has P1 ever try to upgrade to P2?
Or probably just change the whole headlamp from P1 to P2.
Old 12-12-2012, 09:35 PM
  #46
Frank.pierson's Avatar
2013 E550
I had wondered if it was possible to just buy the HID headlight pack.
Quick Reply: Non-HID headlight bulb change
