Sponsored by: CARiD
Installing Active Blind Spot
Old Sep 17, 2010 | 09:07 AM
mjahani's Avatar
2024 GLE350
Hi everybody,
I talked to the dealer to install Active Blind Spot on E350 - 2010 but they said this must be done at the factory, we can't do it here. Is that correct? Thanks
Old Sep 17, 2010 | 10:47 AM
irieblue's Avatar
2007 S550 AMG with ABC
The only company I'd trust to do that conversion is http://www.mbenznl.nl/ . While they are based in the Netherlands, they do travel the world to do the install. Check out the projects on their web site to see some of the upgrades they have done. The Dealers really are not set up to do this type of stuff.
Old Sep 17, 2010 | 02:36 PM
jumper4000's Avatar
E350 Sedan, P2, Driver's Assist, Panorama roof
What's the difference between the active blind spot, and the regular blind spot? Mine is a 2010 model, and I only have the regular one.
Old Sep 17, 2010 | 03:47 PM
Dema's Avatar
i535
Maybe active one locks steering wheel, at least it shakes it for 5 series.
Old Sep 17, 2010 | 04:24 PM
Tjdehya's Avatar
2023 AMG EQS
Active will brake on the opposite side which helps steer you back into your lane. Regular is just the warning and you have to steer yourself back into your lane.
Old Sep 17, 2010 | 04:43 PM
Dema's Avatar
i535
I was in a situation when I started changing line a car was in blind spot; however another car noticing my intention, just started taking my place. So it was funny situation ended by pushing away a car from blind spot to a shoulder. I hope active blind spot system monitors both sides.
Old Sep 17, 2010 | 09:51 PM
jumper4000's Avatar
I agree with Dema, the active thing sounds a little dangerous. Has anyone had any experience with it?
Old Sep 18, 2010 | 01:36 PM
451/443=EW's Avatar
C350 4Matic
Nothing locks the steering, as for the shaking of the wheel, that is a feature called lane keeping assist. It monitors the lines on the road via camera on rear view mirror, and shakes the steering wheel to alert you that you are drifting out of your lane.
Old Sep 18, 2010 | 01:51 PM
petee1997's Avatar
...24 GLE53
I have the non active blind spot assist. It beeps if you are changing lanes when the turn signal is activated and a car is in your blind spot. If you cross the line without activating the turn signal then the lane assist will give you the bumping in the steering wheel. It is a very nice option and I highly recommend it. It is great for easily distracted drivers and fools. I belong to both groups.
Old Sep 18, 2010 | 02:15 PM
Dema's Avatar
i535
I wish all cars in India had the feature. Nobody keeps lane there, so you should use another feature as honk to push car in front of you in lane when you going to pass.
Old Sep 19, 2010 | 08:00 AM
mg-E550's Avatar
2010 E550 4matic, 2008 MDX, 2011 335i Vert
+1
Many times when driving "spiritedly" its gone off and would not have been good to have the car try to pull me back. I guess it comes with an off switch....but I like having the warning without being pulled back.
Where I see it as an advantage is on really long trips late at night when you're tired for added security.
Do you know if you can leave the warning on but turn the active part off in the 11's?
