Last edit by: IB Advertising
See related guides and technical advice from our community experts:
- Mercedes-Benz E-Class: Why is My interior rattling?
Guide to diagnose trouble and recommended solutions
Interior rattles, noises and/or creaking sounds?
#251
Location: Saratoga Springs, New York & Sarasota, Florida.
MB’s
At 1600 miles, I have a thermal plasticky creaking when the AC comes on, or the heat (nowadays) that happens once during the whole drive... seems to come from the roofliner. Occasional creaks over larger bumps in the dash center console area -- also some creaking from drivers side belt buckle receptacle. Had a creaking in the steering column, the whole column was replaced under warranty and resolved this issue.
I have the sport suspension, no airmatic to drown out all harshness with the boaty cushion ride...
#252
Porsche Macan S SportDesign / Ex M-B's: 11 & 10 & 06 E350's, 02 S500
W211's were considered rattle traps by many owners as well, mine being one of them, though I don't remember mine having as harsh a suspension as either of my Sport W212's. For some reason the "eventual rattle" issue has become somewhat of an E Class tradition in modern times for M-B, though I'm not sure about the W210.
#253
MB’s
Rattles
#254
I have a 2012 w212 with left a pillar and rear deck rattles. The rear sunshade was replaced
and it didn't help. I not sure the dealership has done anything about the a pillar rattle at all. Have had car in 4 times already for this alone without success.
#255
![wall](https://mbworld.org/forums/images/smilies/banghead.gif)
#256
Pooping in panorama roof
Hi there...new to MB World. I have a 2010 E63 (CPO) and the popping sound in the roof is unreal. Entering a driveway at an angle, speed bump or pothole at slow speed causes 3-6 very loud popping sounds from the fixed section of the roof. Only had the car for about 6 months and the 3 MB dealers I have asked over the phone about this have never heard of it. I haven't had a chance to take the car in yet. Dealerships are about 2 hours away. Anyone had success treating this?
#257
But whatever they did fixed it as I have not heard it since almost a year ago.
#258
I really do think that rear deck rattles are the covers that conceal the baby seat anchors. I flipped all of them up just to experiment and it seems to not have the rattles any more.
#259
I have an opposing opinion. My baby seat tether anchor point covers do not cause rattles in my car. But I just found one big source for the noise. It is the center brake light assembly that seems to be loose from the rear deck cover.
#260
Oh wow! Going to check mine. You must live in Chicago like me. Crappy streets do not get along with this car.
#261
I have had this rattle at all times. Also had it with the E350 I used to own and it always gets worse in cold weather. I was checking on that long speaker cover on the rear deck but everything is fine with that but then noticed how I can stop the rattle by holding my hand on that brake light assembly when lightly tapping on the deck cover with the other hand.
And it now makes perfect sense. In cold weather the plastic brake light assy shrinks more than the hole around it making it loose.
#263
2013 E350 P1, Sport, Rear Spoiler
They replaced my center light cover... They had to completely disassemble the rear deck... And the rattle is still there. I give up...
#265
2010 C300 & 2014 E350
#266
The dealer expended a lot of effort to anchor all the small loose parts inside the 3rd Brake Light Assembly.
It did the trick.
Just replacing it would probably just continue the same issue as I don't think it got redesigned, to the degree of what my dealer did to fix it.
#267
That 3rd Brake Light is what my elusive rattle ended up being.
It did the trick.
It did the trick.
Thanks for the info. I also think the rattling sound comes from the inside of that brake light assembly and is just worse now when during colder weather the whole assembly seems to be loose.
#269
Does anyone have instructions of how to take the rear deck apart?
I'm thinking now to tackle the center brake light rattling issue myself as I doubt the dealer will do a perfect job at it. It should not be that difficult job to do it myself, or is it?
#270
I have an AllData subsctiption.
If you PM me your email I can send you what they have on it.
I can also send you a parts blow up from the EPC.
#271
It sounds like the harddrive seeking inside the COMMAND unit. I wish they used SSD in them. It's random too.
They car is so quiet around so we end up hearing little noise from the new technology
My car is at the shop now for this
LI91.40-P-057018 SEPT13 – 212, 176, 242, 246, 204, 117, 222 creaking noise from left or right front seat belt height adjustment mechanism, replace belt height adjuster.
#272
i have this noise that seems to me like wire hitting metal coming from under my driver seat ..... its so farking annoying.... I have the multi contour seat... anyone experience this ?
#273
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
My previous 2012 had none of these rattles or creaks.
#274
Yes. I thought it was my fat rear making the seat creak but I tried doing the "family guy - bird dance" and that wasn't it. I'll trouble shoot that sound when they resolve my seatbelt adjuster area rattle. I'll have a pack of small cable ties ready. ![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
TEKTON 6235 Assorted Cable Ties, 200-Piece - Amazon.com
My door was creaking too when i rested my left arm on it but I fixed that by inserting a little rubber piece in the gap.
Let me know what you find.
#275
If the door creaks changes with weather/temp then I'd give the rubber door seals a nice clean wipe down and apply a thin lube of silicon grease.
(this product is the offical grease for S2000 convertible owners to keep the seals fresh and prevent dry rotting.)
It worked well on my wife's old E60 530i. Old school Mercedes used to use fabric covered weather seals and modern ones are pure rubber. Any dryness will make rubber on rubber creaks.
