- Mercedes-Benz E-Class: Why is My interior rattling?
Guide to diagnose trouble and recommended solutions
Interior rattles, noises and/or creaking sounds?
Sucks to hear that anyone is having rattle problems. It easily ruins the experience of driving/owning a car, and is difficult to get fixed on some occasions, at least without being extremely diligent with a Dealer, and being able to diagnose it/have it happen while in their presence.
I recently started to get a creaking noise from the front driver's side of the car when I go over speed bumps or other low speed bumps. Not sure if it is from the wheel well or somewhere in the engine compartment. I think it may be a similar creaking when I push down on the hood over the wheel well and the hood creaks.
Anyone has similar issue and have the dealer fix all the problems?
1. popping / cracking sound coming from roof pano. I had this almost happen in the first 3 months. Was like this for 7 months before i finally took it in. Dealer fixed it, they told me they "cleaned it". But i think it was grommets popping out of place and they probably just removed the gromets! A quick short cut fix. Whatever they did, it worked great. No cracking / popping anymore.
2. the creaking is the center vent. took that in too, they have TSB on this, they just add some felt chalk on the back of the vent. Fixed it for a few months, now it's creaking again. will take back again to fix, but hopefully this time it'll be more permanent.
Hope that helps.
Recently everything was good, and now some sounds from the rear are popping up again. I can't stand even the slightest vibration/rattle/squeak sound, makes me want to drive the car off a cliff (without me in it).
I was going to post a picture of this, but did not get around to it.
I have a 350 that is only 3 months old. I HATE interior noises....really bugs me. Unfortunately, a $60K mercedes has them pop up just like any other vehicle....sucks
I had a ticking noise coming from the dash. Since I have experience tracking these things down, i took the car down a crappy road and started tugging and pushing on surfaces until the sound stopped or changed. Sure enough, it was up in the gauge cluster region. At first, I though it was the far left vent assembly because the noise would stop if I pressed down on the corner of it. I took that assembly out and all looked solid. After reassembly, same story, ticking came back.
I decided that since the pressure was working, it must be something close to the vent assembly that was making the noise. I started pushing on the inner-shroud piece just above the guages...it seemed to also stop the noise.
With some gentle tugging, the ineer shroud pops right off. I could see there were two main points where the plastic guides appear to be the most likely culprits. Sure enough, I applied the soft side of a self-adheshive velcro strip, about one inch long, right next to the pins and guides. This provided soft pressure on the guide and snugged them up.
Re-assemlbed the shroud and the ticking dissapeared.
I hate this stuff, but happy I found the problem...of course, I would have torn the entire car apart to find it eventually...either that, or the car would have been sold.
Ok, I actually have a picture from the dealer that will work. It is the trim piece right below the dash and above the guages. Here is a picture that partially shows it. I have a loop around it.
I do have a w220 and screen name has w220. thanks
