Clear and Smoked Bumper Light fitment
Old 01-16-2011, 04:51 PM
DNAPoPo's Avatar
2010 E550 Sport Sedan Blk/Blk
I tried out a couple of clear and smoked bumper lights today, and they all seemed to be a little bit loose, is this the case with everyone's?
Old 01-16-2011, 04:55 PM
BPhillyBenz's Avatar
'11 350 4matic - '14 Stingray: Gone, BMW 530i, Porsche 944 Turbo, Porsche 356, Mitsubishi 3000GT
If you are talking about the side marker lights (replacing the orange), mine were extremely snug. Had to force them in, but they are a tight fit. All A-O-K
Old 01-16-2011, 05:03 PM
Pntblnk's Avatar
2017 S550 Iridium / Black Nappa, 2015 GL 550 Paladium Silver
Where did you buy yours from? Wanting the pick a set up but reading mixed reviews. Thnx
Old 01-16-2011, 05:12 PM
I swear by mine. Bought em off ebay (but I forget which vendor)...sorry.
Here are helpful DIY instructions posted awhile back from "doctordel".
1) turn the steering wheel to the opposite side your are working on
2) pull the front fender liner from the fender with a good yank; make sure you don't lose the fastener that pops out
3) turn the bulb socket counterclockwise and pull the bulb and socket out from the inside of the lens
4) use your fingers to pull out on the rearmost side of the lens and-once it is free from the fender-pull backwards towards the rear of the car to free the front of the lens from the bracket inside the fender
5) reverse the process with new lens and then reinstall the plastic fastener that popped out.
The hardest part of the whole process was aligning the replacement marker with the box housing behind the fender. You have to do it by feel because you cant see where you are connecting the two pieces. On complexity scale I'd give it a 3 out 10. Pretty simple. It should take you about 20 minutes to do both. Good luck.
Old 01-16-2011, 05:23 PM
EmE247's Avatar
Current: 2011 W212 Previous: 2008 W211 2006 550 2001 Rover 1997 W210
Just my opinion, but get the stock ones painted body color to match look best.
Old 01-16-2011, 05:37 PM
fromthebeginnin's Avatar
Black W212 E550
I have the smoked they are a little loose but ok, did you paint yours yourself or did you have them done?
Old 01-16-2011, 05:51 PM
EmE247's Avatar
Got the markers done at HMS in Westminster when they did all the other mods. Left the car there for a few days right after purchasing it so they could do the work.
Might be a better idea to paint the aftermarket smoked or clear sidemarkers instead. My sidemarkers light up the amber color when lit even thru the paint.
Old 01-16-2011, 06:07 PM
park423's Avatar
'14 ML350 GONE-'12 GL450/'10 E550/'10 ML350/'09 C300/'07 ML350/'03 E320
I got smoked ones off eBay but had them installed at a shop, they look and fit tight, very happy with them
Old 01-16-2011, 06:31 PM
RNBRAD's Avatar
W211 E320 & W212 E550
On the front edge lip where it grabs the plastic of the bumper, mine wouldn't slide in they were too tight. Had to use a drennel to open the gap up on the lenses to fit the thickness of the plastic of the bumper, now they are snug. Got mine off ebay.
Old 01-18-2011, 03:36 PM
DNAPoPo's Avatar
I just have to find the right vendor I guess, I figure these would have all come from the same factory....
Old 01-18-2011, 06:37 PM
MBraced_-'s Avatar
2009 C350, 2010 E350, 2011 E350
I bought my clear ones from this guy.. the sidemarkers are extremely snug when I installed them
http://cgi.ebay.com/ebaymotors/2010-...mZ170592152426
Old 01-18-2011, 07:02 PM
DNAPoPo's Avatar
Thank you so much! I will give this vendor a shot.
Old 02-12-2011, 07:15 AM
hyperion667's Avatar
Received 3,402 Likes on 2,847 Posts
2012 CLS63
yes, mine were just a TAD off.........used some a sticky substance to keep them in a bit better, but still need to nudge them a little every couple of days...........
Old 02-12-2011, 01:13 PM
Real good solution if they are a little loose (mine are super snug) is to go to Home Depot, buy a small tube of clear silicon, place a small bead around the side marker and put it back in place. Make sure you have a damp soft cloth to wipe off any excessive residue on the body. Good luck.
Old 02-12-2011, 02:07 PM
lyjw88's Avatar
C63s ED1 Coupe
mine were extremely tight, so I even had to sand it down a little.
Old 02-13-2011, 03:18 AM
g2k
g2k's Avatar
2012 CLS63,2011 QX56 4WD ,2009 LS460L,94TT SUPRA,2005 S2000
I got mine off of eBay (clear)and they fit perfect
Old 02-13-2011, 04:17 AM
DNAPoPo's Avatar
In the end, I just ended up having the stock one's painted... perfect fitment, and exact color I wanted. Kinda got lucky that it was super inexpensive since I was doing other work as well.
Old 02-13-2011, 08:18 AM
Pntblnk's Avatar
For those who painted the current markers how well does the signal light shine though or did you use a special paint?
Old 02-13-2011, 08:34 AM
K-A
K-A's Avatar
Porsche Macan S SportDesign / Ex M-B's: 11 & 10 & 06 E350's, 02 S500
+2.
For those of you who aren't going the clear route (obviously you have to buy those aftermarket), I strongly recommend just tinting/wrapping/painting the stock ones. I don't see the point in spending more on an aftermarket unit who's fit is un-superior to the originals, when you are getting a simply tinted pair.
Old 02-13-2011, 09:20 AM
2012 CLS63
thanx man, I might try it..........
Old 02-14-2011, 03:42 AM
DNAPoPo's Avatar
Light shines through just fine on mine, and still remains amber to boot. Not sure what type of paint the shop used tho.
Old 02-14-2011, 09:51 AM
Is it possilbe to take a quick picture, so we have a reference? Thanks.
Old 02-14-2011, 02:41 PM
K-A
K-A's Avatar
FYI on mine. I had them vinyl wrapped, and NO light shines through. Just a little amber glowing around the edges, which looks decent on its own IMO.
Old 02-14-2011, 03:25 PM
DNAPoPo's Avatar
I'll get some shots for you tonight.
Old 02-14-2011, 03:32 PM
JBellz's Avatar
2011 E350 / 2009 911 Track Car
I laid tinted vinyl over mine and the result was great and cheap
Quick Reply: Clear and Smoked Bumper Light fitment
