Sponsored by: CARiD
Keyless-Go and trunk access
Old Mar 22, 2011 | 08:02 PM
GeoE63's Avatar
E63 AMG
I have Keyless-Go option and every once in a while I cannot open the trunk with the key nearby. I have to either press the button on the key or pull the trunk release on the driver's door. Has anyone else had this problem?
Old Mar 22, 2011 | 08:31 PM
ttoE550's Avatar
2015 GL450
Just before I learned that I needed to replace my keyless-go battery (very, very easy btw), I found that if my body was between the key and the car, it didn't always work. E.g., key in right pocket, turned to open trunk with left hand.
Old Mar 22, 2011 | 10:39 PM
hanjaya1's Avatar
'11 E350 4MATIC
I have exactly the same issue. When it happened, I recorded with my Iphone and showed it to the dealer. I put my briefcase inside the trunk daily. So I open and close the trunk 4 times a day. It fails to open once a while, even if I bring the remote keye next to the trunk. As you said, I have to grap the door handle to unlock the door so I can open the trunk whem this glitch happen.
During my A service, dealer could not reproduce the issue and put the note on my record. This is the only unresolved issues I have. If you find the answer, please let me know.
