Not sure if this is by design...please help!
Hey guys,
-I got into my car
-Turn car ignition to ACC2
-Turn radio on
-Called mBrace from the console, spoke to them for about 5 minutes to activate the trial
-I disconnect from mBrace and since the radio was on prior to the call, the radio is back playing
-I turn the car off (stereo is still on) and pull the key out (stereo is still playing)
-I exit the car and arm the alarm (stereo is still playing)
-I check back in 5 minutes and Fergie is telling me about her Humps.
Is that by design?
-I got into my car
-Turn radio on
Is that by design?
2012 S350 Bluetec 4Matic, Diamond White, P2
It is likely you pressed the power button. The radio can be powered on without a key in the ignition. It will play for approx 1 hour and then shut off.
Every time you get out, make sure your screen reads 'Dont forget your key' - or something like that. Thats a guarantee that it will shut down once you open that door. Your mobile will lose connection from MB, radio will fade and shut up, even your garage will not close from MB once you open that door.
