Sponsored by: CARiD
New E550 4Matic with vibration in steering wheel
Old Jul 27, 2011 | 09:38 PM
ryip49238's Avatar
Hi Everyone,
I am a proud owner of a 2011 E550 4Matic that still has under 1000 miles.
Over the course of the month that I have owned the car, I have noticed a slight vibration (more like a buzz or resonance) coming from the steering wheel and brake pedal. This only occurs after I have driven my car and come to a complete stop.
The vibration stops when I turn off the AC or while I'm driving. The car remains calm even when I turn the AC back on while still at the same stop. But when I accelerate and stop again, the vibration often returns.
Has anyone noticed this with their vehicle? Any guess on what this can be resulted to? The service department couldn't find anything and told me to add more mileage to the car so that they can check the engine codes and to let the computer learn my driving style (since it was still in "open loop"). I am doubtful that the problem will disappear and don't recall this behavior in the test car that I drove.
Thanks for any advise,
-Brian
Old Jul 27, 2011 | 09:48 PM
Oggypa's Avatar
E550
Me too
I have a e550 and the same thing is happening to me dont no what it is
Old Jul 27, 2011 | 10:22 PM
Tjdehya's Avatar
2023 AMG EQS
If it vibrates when you turn the AC on and then stops when you turn the AC off... then one would believe that its the AC. Seems Logical to me?!?
Old Jul 28, 2011 | 12:10 AM
ryip49238's Avatar
Sorry if my description wasn't very clear but the vibration doesn't always occur when the AC is on. For instance, when I start the car, there is no vibration. Also when I'm at a stop and turn the AC off and then back on, there is no vibration.
The vibration only occurs when I accelerate and then come to a stop. It doesn't matter if the engine is still hot or cold.
-Brian
Old Jul 28, 2011 | 10:52 AM
ttoE550's Avatar
2015 GL450
I'm nearly 100% certain it is the AC compressor. I had the same issue when I first got my car. It was quite alarming when it occurred.
The AC is a complicated thing, so having the vibration stay away after turning it off and then back on might not mean much -- the compressor might not be working as hard when you turn it back on. But if the vibration goes away when you turn off the AC, well that's pretty good info.
I think maybe the vibration is strong now because your car is new. My car is now 1.5 years old with 12K miles, and the vibration for the most part is gone. Sometimes I will feel it when the weather is really hot and humid, but nothing like when I first bought my car.
Old Jul 28, 2011 | 12:18 PM
Tjdehya's Avatar
2023 AMG EQS
How about spend a day driving with the AC off, if you never feel the Vibration then....
Its the AC.
Old Jul 28, 2011 | 06:26 PM
ryip49238's Avatar
Its the AC.
Spending a day without AC with our country's heat and humidity would be a cruel way to prove that the car wouldn't experience any vibration based on my symptoms.
I suppose I asked to see if others were experiencing this problem or whether this was a issue about MB's quality control. AC compressor certainly can be the culprit but also curious if it could be related to other possible components such as the alternator, harmonic balancer, engine misfiring, voltage regulation, timing, etc. Certainly, those components could have an impact when the engine is at idle and under load.
Hopefully, the service department will address the issue when I bring it back in a few weeks. Thanks for the feedback so far...and good to know that the problem could fade over time.
Old Jul 28, 2011 | 06:36 PM
JP465NY's Avatar
2023 GLE 450 4Matic; Past: 2019 GLS 450; 2011 E550; 2007 E63; 2003 E500; 1999 E430
Well I brought my car in for a 2 tire bubble fix resulting from a single pothole (3 tires in 4 months) and mentioned this problem regarding slight vibration in steering wheel when braking. Service attributed it to warped rotors and replaced rotors and pads. I was sort of thinking it had to do with the braking system.
Old Jul 28, 2011 | 08:18 PM
carmelissa's Avatar
2011 e550
-Brian
had the same problem mercedes had to give me a new car. had new car for 4months and having the same problem
