backup camera?
Mine comes on when you put it in reverse. It turns on the screen, but that also means the radio comes on when im backing out
If you turn your command system off by moving to SYSTEM, then moving to the bottom and turn off the system using your "control mouse", then shifting into reverse will automatically turn on the video (with no radio) and when you shift out of reverse, the display will again go off.
This is not documented anywhere....found by trial and error.
That's a law suit just waiting to happen....
