Tinted the windows - How to improve AM reception?
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
I tinted the windows over the weekend and now my AM reception sucks. Do you guys know how I can improve it? Are there hidden antennas or amplifiers that I can use?
Any help is appreciated!
edude
edude
The roof antenna is GPS and satelite radio. The AM/FM antenna is usually mounted on the top of the backglass.
Some tint (I think ceramic) will interfere with radio signals. Only way to fix it would be to try a different tint for that window.
or you could try an antenna amplifier which is what the OP asked about.....
2012 S350 Bluetec 4Matic, Diamond White, P2
My experience with the type of interference certain metallic and ceramic tints can cause will not be aided with an amp. The tint is actually reflecting the signal so there is just less signal. While the amps I have tried did "grab" the weaker signal, it was just louder "crappy reception. Maybe your experiences have been different, but, amps can be tricky with the glass embedded antenna. I am guessing the signal degradation you are experiencing is preventing the AM HD radio signals as well. (HD makes AM sound like FM when the signal is present). I would let the shop that did your tinting know. I am sure they will be able to recommend a more appropriate tint.
1953 300 Adenauer, 1971 300 SEL 6.3, 1975 600, 1978 450 6.9
In addition, the OP must be very careful when removing the tint to make sure that the defroster lines aren't damaged.
Dang I wish I knew that back in 03,,,now when I tint the '10 I have to ask questions,,cause the reception was crappy in AM after the tint.
![](https://staticssl.ibsrv.net/autocomm/EvoM/fcotmicon.gif)
Received 3,399 Likes
2012 CLS63
not trying to be funny: what do you mainly listen too on AM these days?
It got so lousy sometimes,,I had a small pocket sized jobby,,tucked under the handrail over the drivers head.Gotta have AM radio.
2004 c230 kompressor sedan sport
was the tint removed then put back on by any chance?? having similar issues and on my mercedes and the antenna is in back windshield glass...
