Does anyone out there really know the problems with DI engines?
So, is there anyone out there with any inside information of this problem if it's true or not what you learned or heard? Mercedes told me the EPA has mandated all cars are to be at a certain level or fuel efficiency by 2015 and therefore the DI and turbos to get more efficiency from these engines.
It sure find it frustrating when a potential buyer can't get an honest answer. Pretty soon all cars are going this DI way from what I saw.
Your input is appreciated.
Toban
I had a DI engine for three years and it was flawless.
All of my exchanges with forum member for that car and talking with my service manager has never mentioned "carboning"
We can only hope that manufacturers find a solution because DI is one of the easiest way to preserve power while increasing mileage. MB has been very conservative and does extensive testing in the US, so I'd opine that we don't have much to worry about. BMW, OTOH, is always on the forefront of bleeding edge technology so they get bitten more often.
Manufacturers have learned from the early days of catalytic converters and know that they can no longer sacrifice power and driveability for emissions/economy so they'll get this sorted out.
It'll be interesting to see when BMW catalytic converters start to fail.
2012 AMGs.
There is another thing to consider and that is engine oil being contaminated by the fuel because of the high pressure. I read a piece by an engine builder who said that with his DI engines, he changes oil more frequently (5K miles).
Added to that are other considerations including high pressure fuel pumps along with complex and expensive injectors.
Since the majority of E-Class owners lease their cars, they aren't concerned but for those of us who own our cars and hope to keep them for some time, it is a concern.
I decided to order a 2011 E550 when I learned what was coming in 2012. I have an engine that's been around for some time and according to the UK government tax data, it actually gets a bit better fuel economy than the 2012 E500 (E550 in the U.S.)
So if you lease your car or have deep pockets, you shouldn't worry. Otherwise, you should understand that there may be more maintenance costs down the road compared to cars with port injected engines.
US gasoline has nothing to do with carbon build up. Walnut shell blasting to clean it up is used in Europe as well as the States. Claims of increased efficiency and performance may justify the process.
Haven't heard much about NA motors having trouble with carbon build up, but have heard much about FI motors with DI having all sorts of failure.
MB claims they introduced DI in 1956 on the 360SEL or something. It's all how the mfgr implements the tech. Some do it much better than others.
The NA DI 4.2L V8 in my last car (Audi S5) started having really bad cold starts and multiple cylinder misfires at 50k. At 55k, a couple chunks broke off and ruined two catalytic converters. Audi repaired under warranty, and tore down the engine to clean out the rest of the buildup. When I asked the tech what it looked like, he said one word "disgusting". In my research for other occurrences, many people didn't notice the loss of power, but did comment about a rough idle at start. They didn't do anything until the CEL came on. The DI problem is usually related to the EGR (Exhaust Gas Re-circulation) system. Some soot gets in there and over time it just continues to gum up and once a base coat is there, it gets worse exponentially faster. Some manufacturers use a catch-can design to protect it, other companies require the gas to have the additives, others use valve timing.
Here is a link to a great article on the problem: http://www.edmunds.com/autoobserver-...-adopters.html
I am hoping that MB did a great job with the design of the DI BiTurbo V8 in my car and the note in the manual about TopTier Gas is just a precaution. Here in SW PA, it is nearly impossible to find a gas station that is on the Top Tier Gas List. I am curious to see how the new 2012+ american models with DI 4 cylinders handle all the cheap gas here.
I'm only using Chevron gas in my C250 and crossing my fingers (and planning to sell the car around yr 5 when the new C's will have been out for 1-2 yrs).
https://mbworld.org/forums/c-class-w...n-buildup.html
Regards,
Don
http://www.burgertuning.com/BMW_335_oil_catch_can.html
We'll see how the E400 (3.0 turbo) will do ....
I'm not an automotive engineer (nor did I sleep in a Holiday Inn Express last night), but it seems fairly obvious the exhaust gasses (blow-by, oil, what have you) that get recirculated to cut emissions are the likely source for the gunk build up in intake ports and on intake valves.
Looks to me like an unexpected side effect of two efforts - reduce emissions and improve efficiency. I'm sure real engineers are beavering away on solutions.
Regards,
Don
