Sponsored by: CARiD
Speed Dial????
Old Dec 9, 2011 | 09:14 PM
enzo thecat's Avatar
2016 GL63 AMG, 2012 E550 4 matic
Speed Dial????
Can someone please tell me where in the instructions it talks about programming the speed dial entries on the numeric pad on the console?
When I hold down a number for speed dial to activate it just gives me an alert that says that that entry has not been programmed. I can't figure out how to program the digit. I cant find anything about it in the owners manuel and I've looked several times.
FYI: I have an iphone 4s
Thanks in advance,
e
Old Dec 10, 2011 | 09:04 AM
aeggroup's Avatar
2025 Range Rover, 2022 BMW M850 , 2017 MB E400 Coupe
You don't have to do anything special to set up speed dial. It comes from the phone. Check your phone settings. Have you transferred your contact book to Comand ?
Old Dec 10, 2011 | 01:51 PM
My iPhone has a "Favorites" list as a speed dial resource. It is its own menu. I have that full. It does not have a speed dial that is assigned to a numeric key. Maybe that is the problem. I wonder if there is a way around this.
e
Old Dec 10, 2011 | 05:38 PM
Got it figured out:
There is a menu in the command system. If you go into the phone menu, there is a selection for speed dial. It is a display of the assignments for each speed dial. If you open the item, there is a small icon to the right that looks like a page. Scroll to that page and it will let you assign your speed dials to your contact lists. This is independent of the any favorites or speed dial assignments that are stored in the phone itself. Also figured out that if you use the command dial to scroll to a digit and hold down the command knob, it will dial the speed number.
Pretty Neat!!
Old Dec 15, 2011 | 01:26 PM
cvinfig's Avatar
2017 S550 cabrio
https://mbworld.org/forums/e-class-w...short-cut.html
I stumbled onto a short-cut to access your list of favorite telephone numbers stored on your iPhone. When in the phone screen on the MB Comand system, simply press and hold the numeric pad key corresponding to the favorite on your iPhone. For example, my home number is the first number on my iPhone favorites list and my wife's cell is second, and so on. To call my wife's cell, I just have to press and hold the number 2 button on the Comand system. To call home, I press and hold the number 1 button
Old Dec 15, 2011 | 08:10 PM
This doesnt work at all. I found this thread in my search for an answer. Tried it and it was a bogus suggestion (at least for a 2012 E550)
Old Dec 15, 2011 | 08:17 PM
venchka's Avatar
2004 Volvo XC70; 2012 GLK 350 4matic
Y'all don't have voice dialing?
Wayne
Old Dec 15, 2011 | 08:37 PM
Wayne
Yes, but I absolutely hate it.
Old Dec 16, 2011 | 08:36 AM
venchka's Avatar
Cool
Interesting.
Wayne
Old Dec 16, 2011 | 09:38 AM
cvinfig's Avatar
2017 S550 cabrio
Ah, sorry, missed that you had a 2012. It does work as advertised in my 2011...
