Sponsored by: CARiD
Headlight Project on W212
Old Dec 18, 2011 | 01:14 PM
JBellz's Avatar
2011 E350 / 2009 911 Track Car
A friend of mine has a W212 E class and decided he wanted the inside of his headlamp housings satin black. We located a set of aftermarket headlamp housings to experiment with. We tracked them down online and they were less then half of dealer cost on the OEM light so we figured these would do for our project.
Well long story short, all of these newer style headlight manufacturers use urethane to seal the housings and boy its no easy task to separate them After and using a ton of heat and muscle we were able to get them apart. Once apart I was able to see why this light was half the cost of the OEM light :roll eyes:
We removed all of the chrome plastic finishings inside the housing and had our buddy prep them for paint. A fews hours later we had a beautiful set of satin black reflect ( contradiction ) Reassembly took place and and the lights were installed back in.
Side note : If your going to do this, pay the extra money and get the OEM housings. Fitment blew on these but after some tweaking they were in
Old Dec 18, 2011 | 02:29 PM
Yosheego's Avatar
2011 E550
Dood!! Wow! I'm still debating whether I should pull it mine apart. I have the
P2 package and I might mess up the leveling system. Btw, those grill painted?
Old Dec 18, 2011 | 02:37 PM
JBellz's Avatar
I would suggest trying to score a used head of OEM replacements off Ebay or something. This way you don't have to rush the job and you will also have a spare set in case you want to put your car back to stock.
Front Grill is painted Glossy black .
Old Dec 18, 2011 | 04:14 PM
hyperion667's Avatar
2012 CLS63
it's a nice look, have it on my 63
Old Dec 18, 2011 | 06:45 PM
Yosheego's Avatar
2011 E550
Imma start looking...what would be a fair price you say?
Old Dec 18, 2011 | 08:43 PM
JBellz's Avatar
I would say $650 - $800 per side.
Old Dec 18, 2011 | 08:49 PM
MCF's Avatar
MCF
E350
Looks nice and thank god dickperion agrees!!
Old Dec 19, 2011 | 07:37 AM
K-A's Avatar
K-A
Porsche Macan S SportDesign / Ex M-B's: 11 & 10 & 06 E350's, 02 S500
Looks good, very clean. With an OEM housing that would be a great setup!
I would prefer a liiitle more contrast inside the housing, more like the E63's stock lights, and with P2 lights (which it looks like the O/P's car isn't?) you'd be able to see the LED "crystal bulb" parking lights really pop out and look cool I'd think.
Old Dec 19, 2011 | 08:02 AM
captj3's Avatar
2019 CLS450 4 Matic 2011 E550
Has anyone with a P1 package switched out the headlight assemblies for the HID's from a P2 package? Would they work?
Old Jan 26, 2015 | 12:25 PM
ibedanny's Avatar
2011 E350
That looks awesome. Sat I just turned in my leased 11 e350 with P2 and bought a 11 e350 w P1. The numbers just made sense. I actually own and run a custom auto lighting shop def planning on doing a bixenon projector swap and gloss black internals. Even more so now that I have seen it done looks good man!
Old Feb 1, 2015 | 12:08 PM
The Ryno's Avatar
2011 E350 Bluetec
ibedanny, I also have the 2011 w P1. As a lighting expert, I would be curious to hear if it is possible for me to retrofit p2 xenon headlights? I have never really bee able to determine if this is actually possible. I would love to hear your thoughts!
Old Feb 1, 2015 | 12:12 PM
ibedanny's Avatar
2011 E350
I know its possible very expensive there is a member who has done it. I plan on opening them, retrofitting bixenon projectors some custom led work and paint I'll be sure to post pics when done. I have a few paying jobs first but this is on the top of my list.
Old Feb 2, 2015 | 10:15 AM
valleywine's Avatar
2011 E350 sport sedan
Xenon lights
What's the difference between the stock xenons and using a hid retrofit kit? The halogens still have a projector, right?
Old Feb 2, 2015 | 03:54 PM
Mud's Avatar
Mud
2011 E-350 4Matic Sport
I've done some retrofits before as a rank amateur, using Morimoto single projectors as well as E55 bi-xenon (shutter equipped) projectors. Both used D2S bulbs. I chose to install the Morimoto Elite 35W kit into my P1 (halogen projector) equipped E350 and was pleasantly surprised at the light quality, output, and cutoff. I would never install HID's into standard housings but the halogen projectors seem to do a decent job of it.
The main thing I found on the M and E55 projectors was that the cutoff was a bit sharper than the kit I installed but (for me) not enough to warrant a full retrofit. The P1's also retain a clear double step cutoff (driver lowest, step up to passenger, step up to right shoulder). Overall, IMO I found the install of this kit to be both cost and light effective.
I'd be interested in seeing how a bixenon retrofit project winds up - in past retrofits I installed a diode in the harness so that the low beams stay on when the hi beams are selected to activate the shutters. For those wondering what the heck shutters are, they are metal plates attached to a solenoid. The plates block off a portion of the light output for low beams, then flip up (or down) further for full lighting for high beams. In a retrofit to a single bi-xenon lamp, if the car had separate hi and lo beam lamps, you need the diode (or wiring mod) to ensure that the HID bulb will stay on when hi beams are selected and that the hi beam selector now activates the solenoid. This is because typically the lo beams turn off when the high beams are selected in most OEM applications. If you didn't modify the wiring your new lights would go off when you clicked the hi beams on.
Clear as Mud
Old Feb 2, 2015 | 06:39 PM
aquinob's Avatar
2010 E350, Sold 1998 C230
What gets me about this whole discussion is that people are treating the headlamps as ornaments that can be modified by painting the insides black or installing bulbs that the projector/reflectors were never designed to use. Any modification of a headlamp assembly with a xenon bulb where a halogen was originally installed or changing the reflectors is ILLEGAL.
Headlamps are safety equipment, and unless you have a degree in engineering, work in optical design and are familiar with DOT safety regulations then leave them alone. It's not just how well you can see down the road, its what other people have to deal with when they stare down your modified lights. Police can pull you over and ticket you if they find that your lights are modified. Think about the other driver FIRST.
Old Feb 3, 2015 | 07:47 AM
Mud's Avatar
Mud
Good lecture. I'll be leaving this setup in place though, not too worried about who likes or doesn't like it without even seeing it.
What gets me is that even the OEM factory setups in vehicles seem to be getting more and more intrusive, SUV's seem to be at the forefront of this, blinding.
Wonder if they are also thinking of the other driver FIRST.
Endless topic on all lighting forums....
Old Feb 27, 2015 | 08:54 PM
fox3232's Avatar
2012 E350 4MATIC
Ease of opening
How easy was it to open the housings? Did you find a diagram anywhere? Please help.
Old May 6, 2015 | 01:57 PM
ibedanny's Avatar
2011 E350
I finally got around to doing mine they were NOT easy to open but retrofitted evo-x r projectors, dumy projectors in the high beam with high output leds for the P2 look, led demon eyes (colro changing) controlled by my iphone, gloss black painted internals.
Old May 6, 2015 | 08:47 PM
Ed99's Avatar
E63s AMG
Good work. How long did it take for the entire process and how much were the parts?
Old May 7, 2015 | 07:54 AM
ibedanny's Avatar
2011 E350
Parts ended up around 600. time was took about a week start to finish seeing that I worked on this on the side so kinda hard to tell. I will say this Im building a set now for a customer running around $2k. majority of this is labor
Old May 7, 2015 | 07:02 PM
DJ Hellfire's Avatar
2013 E350 Sport
Yeah, most aftermarket OEM replacement parts have terrible fitment.
Old Mar 9, 2016 | 10:27 PM
Abrown3mtg's Avatar
2010 E550 4Matic Sport P2
Do you have to pull the bumper cover off to remove the lights? What was the process of getting them out of the car? The "baking" of the housings, prying open, etc are pretty well covered in other threads for other makes/models.
Old Jun 16, 2016 | 01:59 AM
Mrmendoza's Avatar
2019 C43 AMG
Is that a black chrome grill? or is it just the lighting?
Old Jul 28, 2016 | 12:23 AM
mrbrianshin's Avatar
2010 E350 4Matic
I need to know how you got the headlight assembly out as well. Did you have to take the bumper off? Or can you just take them out with the screws from the hood? Please let me know!! Thank you!
Old Aug 1, 2016 | 04:14 PM
ElisTwoCents's Avatar
2015 E-Class
Looking good
