Sponsored by: CARiD
Waterless Engine Coolant
Old Jan 8, 2012 | 04:42 PM
mauiTom's Avatar
2024 GLE450 4matic, 2010 Ram 2500 4x4
Any thoughts on using Evans Waterless Coolant
Old Jan 8, 2012 | 08:04 PM
CEB's Avatar
CEB
1953 300 Adenauer, 1971 300 SEL 6.3, 1975 600, 1978 450 6.9
Any thoughts about using the coolant that Mercedes engineers have tested and approved for use with their cars?
Old Jan 8, 2012 | 08:10 PM
mauiTom's Avatar
The Evans Waterless Coolant is a true lifetime coolant and doesn't corrode the metals in the cooling system and the vehicle runs cooler, just asking if anyone has used it.
Not everything Mercedes says & has tested is golden.
Old Jan 8, 2012 | 10:26 PM
CEB's Avatar
CEB
If you want to retain your warranty then you'll need to use coolant to Mercedes specs.
Old Jan 8, 2012 | 10:44 PM
Raygt3's Avatar
2012 E550 Cab
Begs the question, if it's waterless what is it? Actually if all ag-bout tu easiest wa-it's about cooling regular DI water works about the best. You could add surfactants to increase it's heat transfer characteristics but only a tiny gain. Hardly worth the effort over water. Add some propolyne glycol for anti freezing and a bit of anti corrosive and your ready to go. I tend to be suspicious of anything that lasts a lifetime. But thats just me. All compounds of this type degrade over time and heat cycling. They may have a somewhat different point-of view
Old Jan 9, 2012 | 09:41 PM
mnje350's Avatar
2010 E350, 2015 S550
Besides air, and oil coolers, are there any other coolants besides water based used to cool internal combustion engines? I have never heard of any. Also, running cooler is not nessesarily better. If it were, the thermostat, radiator and fans would be designed accordingly.
Old Jan 9, 2012 | 09:50 PM
mnje350's Avatar
And the computer mapping.
Old Jan 9, 2012 | 09:53 PM
boschk's Avatar
2006 CLS500 - Iridium Silver w/ AMG Sportline
You're going to stir up a hornet's nest talkin' all crazy like that! In cased you missed it, we agree.
Old Jan 9, 2012 | 10:07 PM
mnje350's Avatar
I am a nubie to MB. So I ask the question. . . How many MB engines die a premature death using the coolant MB specifies?
As a side question, what is used in the F1 cars for coolant? Water based? I know that scale build up etc is not really an issue in the limited life those engines have, but the thermo properties of the coolant would certainly be important.
Just curious questions?
Old Jan 9, 2012 | 10:22 PM
CEB's Avatar
CEB
Cooling issues are very rare - as are lubrication issues, so there is little incentive to use fluids that don't meet Mercedes specs and risk warranty woes.
Old Jan 9, 2012 | 10:26 PM
Raygt3's Avatar
2012 E550 Cab
Most, if not all race engines will use plain old deionized water. Has superior heat transfer qualities. Also most tracks will not allow the use of glycol additives to water as a leak will be like pouring oil on the surface of the track. Also making clean up a mess, water just evaporates. This is just one of those odd cases where simple and cheap is best.
Old Jan 10, 2012 | 04:14 AM
lunarx's Avatar
07 M6 | 09 RX-8 | 07 LGT Wagon | 17 Bolt
Evans coolant is great stuff.
I used it my other cars and was thinking about using it on the E.
No reason the NPG would not last the life of your engine as there is no contamination from corrosion.
However, I prefer the NPG+, which cools better but does not last as long.
It's expensive, due to the need to flush all old coolant and water.
Usually I flush twice with Evans flush fluid and then do an NPG+ fill and then dump and refill with NPG+ again.
Temps run a little hotter than water but there is no risk of boiling and internal pressure is low. If I had to drive across a long dessert I'd want Evans in my cooling system.
Old Jan 10, 2012 | 06:28 AM
mauiTom's Avatar
Thank you.
Old Jan 10, 2012 | 07:18 AM
mnje350's Avatar
That's kinda what I thought. Why mess with it?
Old Jan 10, 2012 | 07:26 AM
mauiTom's Avatar
And when Mobil 1 came out it was the anti-christ to conventional motor oil until they realized it was better, which I have been using it for 25 years in all my vehicles.
Old Jan 10, 2012 | 12:27 PM
ImInPA's Avatar
2012 S350 Bluetec 4Matic, Diamond White, P2
There are only two issues with using distilled water. 1) Water freezes at 32 degrees. If your vehicle will be in a location that will have seasons at or below freezing, damage to the block will occur. 2) water lacks the lubricating properties that are good for the seals in the water pump. When I was growing up in south florida, I regularly flushed the rust out of my cars and refilled with distilled water. Never a cooling problem. Went through a few $15 water pumps though.
Old Jan 10, 2012 | 02:45 PM
listerone's Avatar
2018 BMW 540d
I first learned of the existence of this coolant a few days ago...can't recall where.I then did some research and learned (unless I misunderstood) that one or more modifications to the cooling system were required to use it.If that's correct it's a deal breaker to me....particularly when the warranty is still in force.
Old Jan 10, 2012 | 03:13 PM
Raygt3's Avatar
2012 E550 Cab
I agree pure water from a utility stand point can be improved upon but I was commenting on F1 race engines, the bottom line there is heat transfer, can't beat water. There are alternatives to improve on DI water cooling but these are not generally available to the public as of today. Copper nano-particles in specific percentages added to DI water will increase the heat transfer numbers by about 30% and is very stable in solution. Still too expensive to produce for commercial applications but remember you heard it here first.
Old Jan 10, 2012 | 09:22 PM
mnje350's Avatar
I am not taking a stance against this stuff. Just wondering if there is any real benefit. I'm thinking no cooling issues with the Benz, and I have not seen anything mentioned about outrageous prices related to changing the spec'd coolant in these cars. The coolant does not seem to have an influence on the performance of the engine so I don't see the help. I can understand arguments for and against the whole K&N discussion but not coolant. Kinda like discussing alternative power steering fluids.
Just a viewpoint. As already stated, not for or against, just curious about the real benefit.
Old Jan 11, 2012 | 02:14 PM
captj3's Avatar
2019 CLS450 4 Matic 2011 E550
Evans works great for the right application. For our E350-550 it is not really worth the expense to change coolant being that they are NA. Now if the cars had turbos and or superchargers plus highly modified that would be a different story.
Old Jan 12, 2012 | 04:14 AM
lunarx's Avatar
There are no modifications needed. After the flush procedure you are good to go. Modifications can optomize cooling performance but are not required.
Evans is very good coolant. However, it is overkill for street driven cars, except for Turbo Engines as captj3 pointed out.
Although, I'd run it in a heartbeat, if my car was out of warranty, as I feel it would result in less chance of cooling related engine repairs, that would be at my expense.
Another good thing is that it helps you find leaks easily due to its coke like odor and not boiling away. Gives you a chance to spot problems early.
