heat / ac issue
And, I might add, it's good for the AC compressor to be run regularly, rather that shut down all winter/spring/fall.
I turn my system off, then use fan button to start the fan and then press AC button to turn off the compressor and have just the ventilation open. Can still use fan button and AC light stays off. That's the theory.
BUT, I'm not sure that really works. If temp is high outside, cold air comes out of the vents or warm air if cold outside. So, is compressor always on if fan or mode is turned on?
In my previous car with Auto HVAC, you could turn it off, then hit AC button for on and then hit it again for off. Compressor would remain off, but you could use fan to bring outside air in.
A/C compressors are much more efficient than they once were. But they still cost a couple MPG. Hey, make sense to me, run the compressor all the time and shut the engine off at stop lights
As for turning off AC compressor, only way is to use OFF button, but then you get no airflow from the vents.
See my comment above.
Is it that you're concerned about the environmental impact or the extra 40 miles you'll get out of your tank, which will save you $5?
Am i in the minority on this one?
I have been servicing Mercedes automatic climate control systems since the 1970's and have learned that extracting the desired result from each version (maybe 6-8 variations) requires a little trial and error. It used to be that if the compressor off or economy button was pushed the compressor was OFF! We have been a 212 owner for only a few weeks, so I haven't had much time to play with it. But at mild temperatures the climate control unit at times unnecessarily defaults to compressor operation.
In any of my modern cars, namely my E's, I've never noticed a measurable drop in MPG with the A/C on. I still have the theory of it embedded in my head, though. I actually remember some of my best MPG coming while my A/C actually happened to be on, I think.
Cars are aerodynamically designed for least wind resistance with windows up.
And.............the SL has an A/C off button
However, in my Benz, even if I turn AC off with the AC button, cold air comes out if temp is about 7-10 degrees higher than the temp setting on the dispaly panel. Does the same thing with heat if temp is 7-10 degrees lower than setting on panel.
So, does the temp setting actually cause the compressor to come on? Or the heat or AC?
BTW, the AC light does not come on when it does this, but air coming out of vents is definitely cold (or warm) air.
I enjoy riding with the sunroof open and maybe a window open when temps are nice.
