E350 Sedan with 20 Inch Rims
Subscribe
Apr 12, 2012 | 02:31 PM
I have 20's. Just replaced what I had with Vossen CV2's which the offsets are perfect. I had 35 offset rear wheel. You'll need a higher offset on the rear to bring that wheel in if you are going with that 20x10.
Reply 0
Apr 12, 2012 | 02:41 PM
I know, I specifically ask the company I bought them from and they called Roderick who gave me the 38 offset recommendation. The wheel comes in a higher offset 40 which would do the trick.
Reply 0
Apr 12, 2012 | 06:23 PM
very nice !
Reply 0
Apr 12, 2012 | 09:37 PM
Reply 0
Apr 13, 2012 | 05:47 AM
clmulli, what is the offset on your vossens. I am working with Rodrick and they are referring me to a shop that can shave the inside of the rims. Anyone with good or bad on this process?
By the way, the car looks amazing with those rims.
Reply 0
Apr 13, 2012 | 06:36 AM
Quote: clmulli, what is the offset on your vossens. I am working with Rodrick and they are referring me to a shop that can shave the inside of the rims. Anyone with good or bad on this process?
Front: 20 x 8.5 with E44 offset
Goodyear Eagle F1, 245/30/R20
Rear: 20 x 10 with E55 offset
Goodyear Eagle F1, 285/25/R20
Thanks and sorry for the crappy picture. I'll take more soon.
Reply 0
Apr 13, 2012 | 09:31 AM
  #32
Those are almost stock like offsets. IMO, above offsets should not be used as a reference by those wanting to go for after market wheels in order to get close to flush fitment look or at least more aggressive than stock. BTW, 10mm more aggressive offsets for those specific wheels and tires would result in a perfect flush fitments.
Reply 0
Apr 13, 2012 | 09:43 AM
  #33
Thanks ThreeMBs, do you have any experience in the shaving process or have heard good or bad?
Reply 0
Explore
Apr 13, 2012 | 10:14 AM
  #34
Quote: Those are almost stock like offsets. IMO, above offsets should not be used as a reference by those wanting to go for after market wheels in order to get close to flush fitment look or at least more aggressive than stock. BTW, 10mm more aggressive offsets for those specific wheels and tires would result in a perfect flush fitments.
+ 1
Reply 0
Apr 13, 2012 | 10:17 AM
  #35
Quote: Thanks ThreeMBs, do you have any experience in the shaving process or have heard good or bad?
Depending on the wheel, most shops recommend not to shave off more than 2-3 mm.. my opinion is unless its necessary(rubbing issues) I would not do it.
Reply 0
Apr 13, 2012 | 10:29 AM
  #36
Biggie, Roderick is standing behind the job and the full warranty on the rim. They say it is not an issue.
There is no rubbing but the rim sticks out a little and I am thinking to potentially lowering the car.
Reply 0
Apr 13, 2012 | 10:35 AM
  #37
You plan on taking off 2mm? Thats minor, youll be fine.
Reply 0
Apr 13, 2012 | 10:39 AM
  #38
How much are they willing to shave off in the rears? You need 5-6 mms to be shaved off the 10" wide wheels. Your wheels' hub mounting area will be (IMHO) compromised. If it were me, I would not do it. Do they have 10" wheel with et43-45 or 9.5" with et38-40?
Reply 0
Apr 13, 2012 | 10:44 AM
  #39
I have asked if they could handle 7-10mm without structure damage. I am not sure how much they are recommending to take off to make it under the wheel well yet.
They do sell the same 10" rim with a 45et offset, I think they are just trying not to have me send the wheels back after they have been mounted. I would prefer this verses the shaving. What do you guys think?
Reply 0
Apr 13, 2012 | 10:49 AM
  #40
I dont know your tire specs, but if it helps.. im running 40et on a 20x10 rear wheel 275/30 and lowered NO RUBBING. the 275 on a 10 is a slight stretch.. id say 285 with those offsets and lowered youll rub.
Reply 0
Apr 13, 2012 | 10:55 AM
  #41
you should have done your research and got the 45et.. or just shave off 2mm like i did and rock the 40.. BAMM!
7-10MM off is a big NO
Reply 0
Apr 13, 2012 | 11:01 AM
  #42
Quote: I have asked if they could handle 7-10mm without structure damage. I am not sure how much they are recommending to take off to make it under the wheel well yet.
I'd say there's zero chance of that happening.
Quote: They do sell the same 10" rim with a 45et offset, I think they are just trying not to have me send the wheels back after they have been mounted. I would prefer this verses the shaving. What do you guys think?
Try to work out a deal with them for replacement wheels (10" et45). That is your only option.
Reply 0
Apr 13, 2012 | 11:26 AM
  #43
Based on your recommendations, I sent an email to both the dealer and the manufacturer to send me the 45et rims so that I do not have to mess with the process. They guaranteed the fit so I am asking them to stand behind the recommendation, otherwise I stop payment on the charge on my card and then I am sure that will work.
Reply 0
Apr 13, 2012 | 12:09 PM
  #44
BTW, the front offset of et32 is also a bit aggressive for a 9" wide wheel - fronts got to be sticking out by 5mm or so. It is just not as visible (with 235 tires, which are a bit stretched on 9"), as rears are (with much wider 275 tires). That offset would be more appropriate for a 8.5" wheel. For a 9" wide wheel offset right around et37 (+/- 1), which is OEM on E63, would be better, but not sure if its worth for you to press them on that too at this time.
Reply 0
Apr 13, 2012 | 12:38 PM
  #45
The fronts are 8.5 not 9.. I looked on the roderick website 20" is 8.5 front 10 rear.. and you can clearly tell in the photo that the front tires arent that stretched.. if that was a 9" wide that tire would look alot more stretched.. ABOUTROS you should do a lil more research on your wheels buddy. Also a 9" front at 32et would be sticking out a lot more..
site also says for 20x8.5 front they only offer 32 and 45et.. and 20x10 they offer 25,38,and50.. soo if I were you id stick with the 38 and shave off 2-3 mm.. unless there making you custom offsets idk.
Reply 0
Apr 13, 2012 | 01:00 PM
  #46
Agreed on all your points. In the pictures, front wheel does not protrude nor front tire is stretched. I was basing my comments on the specs that were provided rather than on the pictures (we all know how can pictures be misleading and to be fare those pictures are not that great). As you said, I would also change nothing, if rear wheels are available only in et38 or et50, and not in et44 to et46 range.
Reply 0
Apr 13, 2012 | 01:27 PM
  #47
Send the rears back and get the ones with the 45 offset.
Think those would be the perfect size with no need for spacers or shaving.
I would highly not recommend shaving the wheels.
Reply 0
Apr 13, 2012 | 01:41 PM
  #48
I wasn't directing that towards you THREE, I know you know your stuff.. I was just saying that he should get the specs straight before why try and give him proper and helpful info..
Reply 0
Apr 13, 2012 | 01:56 PM
  #49
No problem Big, I know we're on the same page.
Reply 0
Apr 13, 2012 | 02:24 PM
  #50
Guys, thanks for all the input. You all are amazing I wish I would have done a little more home work but I thought I was asking the professionals in the dealer and manufacturer on this matter.
I will let you guys know. Thanks again.
Reply 0
