Popping sound from panorama sunroof.
Old 05-12-2020, 11:14 PM
  #101
Rehabguy's Avatar
E63S
Originally Posted by Stuttgarten
I can report that roof noise didn't occur today. I'm trying to figure out why noise occurred only once after repairs, but that was it. I have a theory and I'm curious what you guys think. Is it possible that pano sunroof was out of place prior to repairs. Once repairs were done, it was under pressure to go back to original right position, and movement up and down my driveway, help it snap back in place. And now since it's positioned correctly, noise is not repeating. Just a wild guess!
I was actually going to add, when I responded to your original post, if you had parked your car on a level/flat surface when performing this fix. Be that as it may, sound is gone, let the villagers rejoice! If the sound should ever come back... then you'll be able to repeat the procedure in less time. BTW, did you end up removing the C pillar trim?
biker349 (11-04-2022)
Old 05-12-2020, 11:39 PM
  #102
Stuttgarten's Avatar
'13 E350 . M276
When I did the repairs car was sitting inside my garage's flat surface. I only removed upper half of B pillar. At the C pillar, I only popped the SRS tab cover. It was really a straightforward job, thanks to all those who contributed to this great thread.
Old 05-18-2020, 11:20 PM
  #103
'13 E350 . M276
The popping noise has returned. Well, the only choice I now have is to redo the removal and retorquing of the 6 bolts. Does anyone know what torque value I should use? Thx.
Old 07-01-2021, 09:36 AM
  #104
TomSCook's Avatar
2014 E350
The Fix Works!
I showed the video to my mechanic, Art Ryan. $240 later, it’s perfect! No popping or cracking whatsoever. My car is quieter and feels much tighter than before. If you have this problem and you’re in Tampa Bay, call Art at 727-384-0400. He can fix anything else Mercedes related too. I’ve know Art for over 30 years. He’s the best!
Old 09-24-2021, 10:20 PM
  #105
RNBRAD's Avatar
W211 E320 & W212 E550
This fix worked like a champ. I went ahead and tightened the ones up front as there's 4 per side but I actually think it is the middle 2 that are the culprit cause those were the ones on mine that were somewhat loose. The others were pretty tight. The front ones you will need to remove the A-pillar covers and the sun visors. A-pillar covers you just remove the airbag emblem and there is a torx nut behind it. Visors are easy, they have a plastic cover over the mount, remove that then just pull the windshield side down to snap out and then slide forward to release.
Old 09-26-2021, 07:59 PM
  #106
The Truth's Avatar
2011 E550 & 2014 ML350
I also have to say that the fix works like a charm. Fixed mine about a month ago and has been smooth sailing ever since. It definitely made me want to invest in an electric torque wrench. Thanks again for the videos and instructions!
Old 09-29-2021, 09:16 PM
  #107
stiknrudder's Avatar
2011 Mercedes E350 BlueTEC
Been a while since this was posted but still helping out. This sounds like a diagnosis and fix that might actually work. Thank you!
Old 09-29-2021, 09:33 PM
  #108
Originally Posted by DEAD CIVIC
Just Fixed mine. Finally some peace. I hated that sound.
NICE!! Thanks Dead Civic! Liked how you got your dig in on your dealer's service rep. I have to say I had the opposite experience with a Chevy truck I got from Car Max. They actually covered some work just outside of their warrantee period. Sorry your shop wasn't as well run. Really nice work on the video, you helped a lot of people that were likely fit to be tied.
Old 10-08-2022, 05:03 PM
  #109
Polarbert's Avatar
W212 2011 E63
My car suffered from this problem and I've just done it myself in about 45 minutes. The video was a great help. I would echo what others have said in that you only need to take down the grab handles, b pillar tops, and the c pillar covers. I couldn't even remove mine because they seemed to be joined up to the rear window shade. But I managed it never the less. I tightened all six bolts with loctite. One of the bolts was only finger tight as well.
Old 11-03-2022, 10:56 PM
  #110
pretsel's Avatar
C250
Having this issue on a c250 coupe. Has anyone used resolved this issue on that model?
Quick Reply: Popping sound from panorama sunroof.
