heating problems
I have some problems with my heating system.
some time is working some time not.
I saw when the outside temperature is lower than 6 or 7deg Celsius heating is ok , when is higher I have just the cold air who's coming on my car, in Montréal at 10 deg is start to be cold in the car.
I check the forum and I suppose it's the control valve but I'm not sure, because maybe this is working or not.
don't have nothing with the outside temperature.
somebody can help me with this one?
Check that your radiator is full of coolant. If the reservoir has level in it does not always mean the engine cooling system is full of coolant. Low coolant level usually shows first as lost heating for the cabin.
strange is why when is much colder outside the heating is working, and when is up to 8, 9 degrees is coming just the cold air.
I put the temp inside the car to HI and it's coming just cold air
it's not posible to be a sensor or fuse somewhere??
It's true what you say, but if you ask for the inside temperature of the vehicle to be 30 deg and nothing happen, it's coming just cold air, and it's really cold inside, normally after few minutes the warm air is coming but in my car after 30 minutes it's just cold air.
when the temp outside is lower than 8, 9 deg everything is working fine
