Article on Direct Injection
http://www.thetruthaboutcars.com/201...l/#more-442513
Regards,
Don
Then I have the dealersip do it and they do use a special machine , rev up the engine at high revs for minimum 15 minutes I suppose .
The mechanics whom I talked to in the private shops recommend Carbon Clean for diesel engines .
.... Of course, they perform efficiently and better than non D/I motors (comparatively) from the get-go, and we don't know their true long term lasting values yet, for better or worse.
This thread on the W204 forum has some photographic evidence of known problems with some DI engines. The thread gets a little personal in places but does thoroughly cover the subject.
Regards,
Don
No reason to rag on DI engines or find excuses on why our model engines are better..Just saying.
Anyone who keeps their cars long term must take into account the potential problems of DI. MB has not given any detail on how they have addressed known problems from other manufacturers. I trust MB engineering, but as Ronald Reagan said: "Trust but verify. "
Regards,
Don
For the S5, I discovered that almost none of my local gas stations were on the top tier gas list. The Mercedes manual explicitly says to make sure you use gas from these stations. It makes a big difference as it helps to keep things clear in the first place.
The list is here: http://www.toptiergas.com/retailers.html
Compared to other things on the market redex or equivalent which are 2/5ths of useless, this stuff really works.
In fact some top end marques Bentley, Lexus etc use it as part of their service.
If you have never used any cleaners and your car has reached say 50k, then the carbon build up will be difficult to clean unless you use one of these special injector systems where they hook up your car and run for about an a hour to clean the whole internals!!!
My wife had a 2007 BMW 335i that had fuel pump issues. I am not sure what caused the problem at the time but it was a common problem on those first DFI TT engines.
However, once you drive these new DFI engines, there is no going back to port injection especially the turbos with high torque.
