Lowering Springs ... ??
Ride quality= Vogtland. I have used them all and in my opinion, a far superior spring that will never sag over time. It also gives you the raked look where the front sits a little lower than the back. It will also depend on which dampers you choose to go with. Koni adjustable or Bilstein HD or Sports. You may or not want to change your spring pad#'s as well.
Good Luck!
I also posted a topic about Eibach springs . If you scour the forums you should be able see it with lots of replies on it
