Sponsored by: CARiD
Question on TPS system
Old Jun 21, 2012 | 12:45 PM
Savino67's Avatar
E350 CDI Sport Estate
Hi, does anyone know how it works , do I have a sensor in the wheel or on the suspension . I just a tyre repaired and the chap stated that there wasn't one in there , strange ..
Old Jun 21, 2012 | 12:52 PM
jvc300's Avatar
2011 E350, 2004 911
The sensor is in the wheel. It's directly connected to the valve stem.
Old Jun 21, 2012 | 02:59 PM
BudC's Avatar
2011 E550, 2013 GLK
I thought it was part of the valve stem. BTW, do not use metal stem caps with the TPS system.
Old Jun 21, 2012 | 03:18 PM
BenzV12's Avatar
W212 FL
I do use this approved MB product :
and another item I have got
Good reminder on the metal caps, but my factory wheels came with the tiny metal caps though
Old Jun 21, 2012 | 03:44 PM
jvc300's Avatar
2011 E350, 2004 911
Sometimes, they are. I've seen the TPS monitor screw on, or mount to a valve. either way there should be a monitor connect to the stem on every wheel.
Old Jun 21, 2012 | 05:33 PM
telemakhos's Avatar
E350 4Matic 2011
Some cars, at least mine, has a simplified TPMS. No additional hardware in the wheels. It just measures rotation speed at each end to determine if one tire is low or not. No direct measurement of pressure.
Old Jun 21, 2012 | 09:37 PM
leapingpoint's Avatar
E-class
that's what i have on mine too...................
Old Jun 21, 2012 | 09:50 PM
threeMBs's Avatar
Only MBs - the best or nothing
There's obviously some confusion with TPMS here.
The OP is probably, based on words "tyre" and "estate", is not US based (GB maybe?).
All US W212 E-class are equipped with so called "Advanced" TPMS with sensor in each wheel with each wheels' pressure displayable on screen.
Non-US cars have TPMS as described by non-US based posters (based on E models specified, which we do not have in the US).
Old Jun 21, 2012 | 11:02 PM
CEB's Avatar
CEB
1953 300 Adenauer, 1971 300 SEL 6.3, 1975 600, 1978 450 6.9
The US mandates a direct system which actively determines the tire pressure and alerts if the set pressure falls by 25%. Most sensors are about a half inch long and are attached to the valve stem and sit on the inside of the wheel.
Some other countries mandate or allow an indirect system which does not use additional sensors but uses existing sensors (abs etc) to determine the rolling diameter by comparing the rotational speed of the four wheels.
This indirect system is not as accurate and cannot account for temperature based or time based pressure loss. It also reacts much slower than the sensor based system.
TPMS has been mandated in the US since the 2007 model year by the TREAD act.
Since the sensors do not alert until you've lost a significant amount of air, you cannot rely on them to replace your monthly checks.AFAIK, the US is the only country that mandates the direct system and one of a very few that uses it.
Old Jun 22, 2012 | 07:00 AM
hyperion667's Avatar
2012 CLS63
sometimes I wish I didn't have those things......haha......always checking them!!!
the other week when I was at the tire shop some guy came in with metal caps on his stems that were fused together.....he wasn't happy when they told him whats happened and how they needed to break the seal and then sell him new kits for each wheel....
