12v outlet no longer in glove compartment?
I couldn't tap into other 12v sources since this accessory has a built in step down voltage regulator in the plug, and thus need to be plugged into the cigarette lighter type of port.
Does this plug in glove compartment require some option we didn't get, or was it a victim of cost savings in the 2012's?
K-A does your 2011 have a plug in the glove compartment?
So this may be a dumb question but a quick search didn't reveal any quick answers. I have a 2011 e350 P1.. is the only port available in my car the "proprietary" MB port in the glove box. I haven't seen a USB port at all. The owners manual would lead you to believe that one should be in the glove box but I am not seeing it. I'd rather not have to pony up the 25 bucks for an adapter if I don't have to.
Nice to have an older 2010 model. I have the 12 V and MB connection in the glove box just like I had in my early 2011 model. I have the standard cable for the iPhone that came with the car and I purchased a cable with USB to connect in the glove box.
With these connections I can just connect my phone and leave it in the glove box as I don't use the phone for texting or email while driving.
With his ipod adapter but no usb slot. Mine was manufactured in august 2011 and does not have the power supply in the glovebox. I do have a usb
Port and ipad adapter in the center console.
For this part your car is a 2012 model, perhaps the whole car is but was sold as a 2011.
This entire wiring procedure required no drilling, removal or cutting of anything. A popsicle stick or comb tucks the power wire behind the trim.
The jack in the glove compartment was very handy for my purposes.
Did I read a 12v socket in the trunk?
I have cigarette lighter package, so, a 12V below the radio.
1. Then a 12V below the air vents for the rear seat passengers(is that 115V by default?).
2. Where do I find the 3rd 12v socket in the trunk. Is that still available for 2014 Facelifted W212 or it got removed completely?
Planning to add this to the car, for that occasional use. Even though the front 12V will be enough, soon it'll be used for the DashCam, dedicated.
http://www.amazon.com/Foval-Power-In...ustomerReviews
And for the cellphone charging, I'm using the dedicated (to this car) iPhone charging cable with the USB port inside the center glove box.
Thanks.
www.amazon.com/Foval-Power-Inverter-Converter-Charger/dp/B01KT26D68/ref=sr_1_1?ie=UTF8&qid=1495729950&sr=8-1&keywords=12v+to+power+outlet#customerReviews
Thanks.
I think they removed our charger from the glove box. The 3rd 12v charger in the trunk is on the sidewall, near the net and cubby opening.
That adapter is handy, but make sure to unplug it when you exit the vehicle.
lol
