Sponsored by: CARiD
What speed gives the highest mpg?
Old Oct 24, 2012 | 12:36 PM
El Cid's Avatar
Veteran: Army
2010 E350 Luxury Sedan, Engine 272 (V6)
I tested my onboard computer when I first got my car and then a couple of times since. It either reads about 1 MPG lower or the same as when I use the fill tank and check odometer method. Used same pump at same station for the testing.
Old Oct 24, 2012 | 01:07 PM
mnje350's Avatar
2010 E350, 2015 S550
Originally Posted by Green E-300 DT
While your onboard computer is somewhat better than a guess, that's about all it really is.
I find that mine will show as high as forty (40) miles per gallon for the entire tank, but when I use my calculator and divide
the miles driven by the gallons used to fill the tank up to the brim
, the computer can be off by as much as five (5) MPG.
With my CDI, I have seen computer readings over several hundred miles on a long trip
as high as 43 mpg, but when I fill the tank, it will figure out to only 37 mpg.
That is how far off some onboard computers can be.
By the way . . . with the fuel economy I am getting regularly, I am not complaining!
DHG
I also question the accuracy of the on board computer. I meant to add that as a caviat to my message. Like you and in general, I am pleased with the fuel economy of this vehicle.
