Oil Dipstick and lights
(1) the oil dip stick in back is green with a flat top and the part number A27209 stamped on it ( the book shows thai it should be shaped as a little O that you put your finger trough), just want to make sure I have the right dip stick and not the one out of the disel.
(2) I have fog lights up front, dual lenses each side containing a fog lamp in one lenses and a small bulb in the other lenses on the same side. What position turns the small bulb turn on?
You have not opened the hood yet?
I check engine oil every time I fill up just like the manual tells you to do.
My E550 is very good with oil as it does not burn any but not all engines are like this. I also change my oil at 5000 miles, which is not by the manual. I intend to keep my car as long as it runs...
