Sponsored by: CARiD
Auxiliary AND iPod?
Old Sep 3, 2012 | 11:32 AM
UK96's Avatar
E350
Auxiliary AND iPod?
So my E350 has the iPod kit installed, but there's also an aux jack in my glove box. I dont have any male to male 3.5mm cables laying around to test this but since the iPod is the default source for audio to the "AUX" option in comand how would I be able to use the aux jack instead? Just plug n play if theres no ipod connected? Change some settings? Remove the entire iPod kit?
Old Sep 3, 2012 | 02:47 PM
alanme123's Avatar
2012 E350
It should be the AUX option when you plug in the male to male jack. I did not have to remove anything. I thought ipod had their own category.
Old Sep 3, 2012 | 05:08 PM
UK96's Avatar
E350
No the iPod just works through the AUX option, not a separate section; I'm about to get a male to male cable so I'll let you know how it turns out
Old Sep 3, 2012 | 05:32 PM
alanme123's Avatar
2012 E350
Well I know as a fact that I use AUX for the male to male connection. I use it all the time. Maybe they go through the same? For the iphone/ipod I can scroll through my music through the car's command system I believe if I remember correctly.
Old Sep 3, 2012 | 06:31 PM
UK96's Avatar
E350
Well I just tried it and it didn't work, do you have both the apple connector on the left side of the glove compartment and the aux jack in front on top? I plugged it in, played the music, and hit AUX and nothing happened I think I might have to disable the iPod kit for this
Old Sep 3, 2012 | 09:24 PM
Dema's Avatar
i535
My media interface have many options, so I can select either iPod or other source as AuX. Actually I use it to play music from my Android phone. What I really miss that the iPod cable doesn't have USB plug (has to be ordered separately). I used to have USB in my BMW, it is very convenient to connect just hard drive.
Old Sep 4, 2012 | 04:03 AM
alanme123's Avatar
2012 E350
I still remember that iPod was its own option.. Aux was just plug it in, choose aux, and playa from your phone/ipod through the earphone jacks. I am not with my car right now but i'm pretty sure if you have the W212 it shouldn't really make a difference on where the plugs are. Are you sure the volume was up on your phone or ipod when you were playing it?
Also, I did not have to remove or unplug anything to use the ipod or aux methods.
Old Sep 11, 2012 | 04:44 PM
UK96's Avatar
E350
well I have a 2010 E350 and I'm 100% sure that I select "AUX" on the center comand console when I have an iPod/iPhone plugged in to play music and that when i have something plugged in with the 3.5mm auxilliary jack it does not seem to work. Anyone know what I'm doing wrong? I dont even think there's an "iPod" option present anywhere in my comand actually..
Old Sep 11, 2012 | 05:22 PM
lexasgs400's Avatar
2010 E550
iphone connection
Will my iphone stream music wirelessly on a 2010 E550?
if so why would you use a jack
Old Sep 11, 2012 | 06:43 PM
BM2BZ's Avatar
w212 E550
if you have bt audio enabled, you don't need a jack but not everybody has the latest software which means no bt audio in their cars.
Old Sep 12, 2012 | 11:36 AM
norcal_cyclist's Avatar
2010 E350
2010 and earlier needed the update iirc - I had the update performed and the bluetooth function is pretty awesome.
Old Sep 12, 2012 | 12:26 PM
ttoE550's Avatar
2015 GL450
BT audio is cool, but it's not perfect. For most (if not all) of us, you cannot use Comand to control the iPhone besides next/previous song and pause/play. Also, if you are streaming music to your phone and then to the car, sometimes the reception gets spotty. I keep a backup iPod in my car attached to the cable.
Old Sep 12, 2012 | 11:35 PM
Dema's Avatar
i535
Planning to get iPhone 5 on 21, hopefully no problem with AUX for this new model.
Old Apr 28, 2015 | 10:51 PM
btv94's Avatar
2007 E350 RWD SP1 (M211.056/E272.964)
Does anyone know how to make AUX jack work? Is there a special aux cable required?
Thanks,
Old Jul 16, 2015 | 02:22 PM
Banillacupcakes's Avatar
08' E350 4Matic
Thanks,
Did you ever figure out what to do here? From other threads I've read the aux is basically unplugged if you have the ipod integration and you just need to get in there and unplug the ipod and plug in the aux. I'm not experienced with these things BUT I figured it wouldn't hurt to ask.
Old Jul 17, 2015 | 11:48 AM
btv94's Avatar
I found out that I don't have to convert my ipod integration to aux.
I just need the right converter from iphone 4 to Lightning 8 pin Cable Adapter with AUDIO CABLE CORD so i can use with my iphone 5.
Old Dec 13, 2019 | 10:51 PM
budgobbel's Avatar
MB CLK 350 2008 A209
OnlyGerman replied to a similar thread of mine. Apparently, both the aux connector and the ipod connector both connect to the command head unit, but only one at a time. Supposedly, there is a splitter or switch that can be used. I will be searching for that, although for me, I believe the ipod cable/jack/connection will be enough. I plan to get the ipod touch and move on!
Old Feb 8, 2026 | 02:59 PM
Octane1Z's Avatar
2006 C230 Sport, 2014 Imfiniti Qx60
What about this mystery aux cord or us android users?
Does anyone use cameras and take photos of the things that are 'secret' also is this just a i'whatever compatible point of audio?
