2010 E350 Not Going From Drive to Park
Absolutely a malfunction if it does not go to park when the button at the end of the stalk is pressed and car is not moving.
Check the little arrows in the gear selector display. The arrows show what gear shifts are possible at a given time, like possible to put it in park arrow should be lit when you are stopped but unlit when the car moves over certain slow speed, which I dont know the value for. If the arrow for switching to park is lit when you stop your problem could be a simple faulty button at the end of the stalk but if the arrow is not lit it could be something more complicated. Luckily it goes to park with the door opening.
Took the E350 to the dealer. They tested it and there was no signal from the steering column module to the shift module which was preventing the car from going into PARK sometimes when I pushed the park button.
They replaced the module inside the steering column and the issue was solved.
All under original warranty so no cost. I really like my E350 and in black it looks sweet.
