Switching to 17" Tires?
Old 11-16-2012, 04:33 AM
Nuru's Avatar
S350 BT 4MATIC
As far as switching to 17"'s, will the speedo automatically compensate or do you need to go to the dealer for an adjustment?
If the speedo and transmission auto-compensate for the tire size difference, I would consider switching to 17's not just for winter tires, but maybe more permanently for the advantage of higher sidewalls on the roads in the east. I would also consider getting even heavier sway bars front and back.
Old 11-16-2012, 06:03 AM
RSIKR's Avatar
2014 W212 E350 4M
The diameter of the 17" standard tire and the !8" tire is about 25.7", so they are the same size and the speedo should not be affected. There are owners who put 17" wheels on with snow tires for winter and revert back to the 18" wheels and tires for summer. The narrower 17" snow tires are an advantage in winter. Not only is the sidewall higher but the tire is narrower.
Old 11-16-2012, 02:09 PM
myzmak's Avatar
2013 E350 Wagon; 2009 328 xi
use a tire size calculator (depends on width, ratio, etc. ie: WHICH 17" tires)
here is an easy to use one:
http://www.1010tires.com/TireSizeCalculator.asp
Old 11-16-2012, 06:49 PM
Nuru's Avatar
S350 BT 4MATIC
Thanks everyone for your responses!
Quick Reply: Switching to 17" Tires?
