20" Wheel Options - Please help
I have a quick question:
I am about to fit some 20" rims to a 2011 E Class.
The widths are 8.5 ET35 front and 9.5 ET35 rear.
My question is about tire sizes.
Would a 245/35/20 front and a 275/30/20 back work?
Can I fit a 275/35/20 back or is that too big? I'd imagine a 255/35/20 would definitely fit back?
I did see those threads which got me a little confused as I was seeing sidewalls of 20 and 25 used. They are not available over in Dubai and need to be imported which are damn expensive to do.
I've basically sold a set of 20" rims to an E class owner and only ever fitted 20" to the S class before so have no experience in tire size. I know the S on a 20 uses 255/35/20 and 275/35/20 and thought I could use that but before ordering the tires, I decided to check and then it came acros a thread where someone was running a 235 as a 245 wouldn't fit - albeit lowered.
I'd imagine 255/35/20 rear will fit as it's the same height as the 275/30 give or take a few mm but now I'm wondering about the front.
Thanks again for your help buddy
