Sponsored by: CARiD
W212 E550 Exhaust Recommendations
Old May 7, 2014 | 03:30 PM
FastE's Avatar
2020 MB-AMG GLC43
Originally Posted by Tracers
FastE, did you do the exhaust work yourself? Where did you get the X-Pipe and j-pipes?
I took it to a performance shop. I am still pondering inserting some fibreglass to soften the crackle a little bit. I am not sure it will work as it does on some muscle cars, due to the way the pressure effects the J-Pipes.
I also feel the J-Pipes I have may be slightly the wrong length. It resonates too loud inside the car at lower RPM's. I cannot find the post that discussed that in one of these forums.
Old May 7, 2014 | 03:51 PM
Tracers's Avatar
2011 E550
Ok thanks. I definitely want to hear the exhaust but don't want it to be crazy loud or drone too much.
Old May 7, 2014 | 04:31 PM
FastE's Avatar
2020 MB-AMG GLC43
The volume is perfect. The J-Pipe softens the sounds under normal load, but opens up under throttle.
The droning is there though... Which I believe can be fixed with the right length of J-Pipe.
