Sponsored by: CARiD
Tire air filling procedure
Old Aug 22, 2013 | 08:27 PM
sdhpapa's Avatar
2013 E350
I have a question. My tires need air. I attempted to put air in using my air tank which has a normal tire air filling end on it. Instead of filling, the tires took no air and then let air out when I take off the air filling device. Is there something different about tire air filling on Mercedes?
Old Aug 22, 2013 | 09:05 PM
Arrie's Avatar
There is absolute no difference in MB tire air valves compared to others.
If the tire did not take air from the air tank then the tank pressure was too low.
If air is comin out from the tire after you disconnect the tank from the valve stem then your valve on the tire got stuck open.
