Does anyone do there own maintenance?
A couple of weeks ago I decided that it was time to get educated and learn how do do Oil changes, Air Filter Changes, and Cabin Filter Changes.
Bizzarely, both my E-350 and GL-450 take the exact same filters for all of that. Bought a supply of MANN filters on Amazon.com, bought a MITYVAC, bought the tool to remove the oil filter cannister. About $100 one time investment in tools and the filters cost about $40 per car. Oil runs about $50 per car.
So, for about $90 per vehicle I am able to change my oil and filters and save about $200 PER VEHICLE from the stealer-ship.
Also, once you learn the "trick" the oil change is one of the easiest I have ever done. Air filters, once you see how its done, takes about 15 minutes total.
If you look at the services that MB says you need, 3/4 of it is complete BS (brake fluid changes every 10-20K...GIVE ME A F'ING BREAK)
I won't knock those who take their cars in for service, must be nice not caring about being ripped off...But it makes me sick.
Not only the cost, but the knowledge that the job was done right and the satisfaction that you can rely on your own skills is a big plus as well
It could lead to a bunch of headaches should that type of situation come up.
I used to do all my own maintenance. (when you do 50k miles a year in a bmw it gets expensive to have dealer maintain it) but found out the hard way what type of headaches it causes when you have to argue with the dealer and manufacturer that your own maintenance meets their requirements and wasn't the cause of whatever was broken.
I now have dealer do maintenance when the vehicle is under warranty to avoid that headache.
In addition to the scheduled service I change the oil myself at half way between the service schedule, i.e. my car has new oil every 5000 miles. Very easy oil change by sucking it out thru the dip stick hole.
But you can still help this. You can ask your service advisor what all is done each time and opt out from it. Like oil change you can do yourself. Just keep the receipts for it as proof it was done. Wiper blades are very easy to do yourself and you can opt out from it.
I think oil change alone runs well over $100 at the dealer, wiper blades are $80 or so.
One thing though is that if you let the dealer do all required warranty service work you will get better treatment for the issues the car has during the warranty period as your relationship with the SA grows.
So the question is if the savings between having all service work done by the dealer against doing it yourself is really worth it?
