Sponsored by: CARiD
Adaptive Lighting Noise?
Old Dec 28, 2013 | 03:34 PM
a2sail's Avatar
2014 - E350
Have a 2014 E350, w/750 miles; with the adaptive lighting system. Upon shut off a whine emits from both headlights for about 15 to 30sec. +-. then quits. the noise will restart upon opening any door. The noise can be stopped by locking the car with the MB key fob. Very annoying.
Dealer indicates this is normal with this headlight system!
Are there fans in the headlights cooling the LED's? or a electronic "can" needing cooling?
thoughts please.
thanks
Old Dec 28, 2013 | 10:01 PM
GregTR's Avatar
2014 E350 Wagon, 2025 GLC 350e, 2026 E53 Wagon
From the WIS:
Thermal management
The front lamp units are each equipped with a temperature sensor for each light function, with which the heat development in the area of the actuated LEDs is recorded. The front LED exterior lights actuation modules evaluate the signals of two temperature sensors each. If the LEDs or the plastic housing of the front lamp units threaten to overheat as a consequence of high outside temperatures or high actuation currents, the front LED exterior lights actuation modules reduce the actuation currents for the LEDs and thereby lower the heat development.
Apart from this, the front LED exterior lights actuation modules actuate the following components to additionally cool the LEDs or plastic housing of the front lamp units:
  • Fan motor 2 for left front lamp unit (E1m5)
  • Fan motor 2 for right front lamp unit (E2m5)
The fan motors are either actuated immediately or with a time delay.
The actuation depends on which light function is active.
The active ventilation by means of actuation of the fan motors is used simultaneously for de-icing the front lamp units at low outside temperatures.
So to answer your question, yes there are fans in the LED headlights and yes, they will turn on in either too hot or too cold temperatures.
Old Dec 29, 2013 | 08:20 AM
a2sail's Avatar
2014 - E350
Thanks!
Greg TR
since I am a tad **** about my cars, your response was most gratifying and reassuring - .
thank you for responding.
a2sail
Old Dec 29, 2013 | 09:20 AM
finman's Avatar
2014 E 550 , 12 911 TTS
Thank-you for this info
was wondering what the heck it was
Old Dec 29, 2013 | 09:43 AM
michael61's Avatar
E 250
Interesting. My E250 seems almost alive when I walk up to it/away from it in the garage. Once it "sees" me (keyless entry) there is always some noise (fans, etc) coming from it.
Old Dec 29, 2013 | 10:48 AM
GregTR's Avatar
Yeah, it can be alarming at first but basically the car is just trying to get ready for you to push the start button. It will prime the fuel pump and get ready to melt the possible ice in cold temperatures or ventilate in hot temperatures.
When you get out of the car the same story goes for circulating some oil around so it wouldn't bake and allow things to cool off properly.
The only time it can be annoying is when all you went out to get was the memory card and you weren't expecting to go on a drive, however your car can't read your mind. Not yet...
Old Dec 29, 2013 | 06:41 PM
DerekACS's Avatar
2015 E250 BT 4M
WIS ?
Originally Posted by GregTR
From the WIS:
Many thanks, GregTR for this information ! Pardon my ignorance, but what is "WIS" ?
Old Dec 30, 2013 | 12:15 AM
GregTR's Avatar
Workshop Information System. It is the official service manual for Mercedes.
Old Dec 30, 2013 | 12:56 PM
mikemargolis's Avatar
'11 E350BTC P2 Leather
In my world, that is a Watch Idiot Savant.
Old Jan 3, 2014 | 09:05 PM
leapingpoint's Avatar
E-class
From the WIS:
Thermal management
Excellent info. Thanks for sharing!
Old Mar 1, 2014 | 02:01 AM
samkimg's Avatar
2023 XC60 PHEV, 2023 XC40 BEV
Is WIS available to us mere mortals?
Old Jan 13, 2022 | 05:25 PM
LJAUTO's Avatar
2014 Benz e350 wagon
Are the temperature sensors in the fan?
From the WIS:
Thermal management
