e550 click when turning, cv axles?
For a RWD car I have never heard of this. The rear CV-joint does not change angle at turns other than if you make a turn so fast it makes the car "lean" to one side. This could make the CV-joint to change the angles beyond the normal wear area.
vehicles will develop a depression at the contact point within the CV joint.
dropping the ride height can then change the wear point on the CV joints.
They will then click in and out of that wear point.
This was a common ailment with S2000's.
