Cost to replace warped rotors?
I don't know if it will be just two or all four wheels. Also, if rotors are replaced, does that automatically mean I'll need new pads as well? The pads are still practically new.
Thanks in advance!
rI don't know if it will be just two or all four wheels. Also, if rotors are replaced, does that automatically mean I'll need new pads as well? The pads are still practically new.
Thanks in advance!
If I was you I would go with an aftermarket rotor supplier unless your MB dealer gives you an exclusive warranty against warped rotors if you get new ones from them.
If the pads are almost new (did they replace them because of the pulsating brake pedal?) they do not need to be replaced. Just a few hats brake uses will wear the pads to the new rotors.
I actually just replaced my rotors and pads in the front due to vibration and pulsing.
Fletcher jones at Newport Beach wanted 770.
Did it myself, bought my parts from socalmercedes.com.
OE Rotors (drilled) 130 each.
OE Pads 75.00
Reused the wear sensor.
Job took an hour - fairly easy if you're a moderate wrench head. If your not into working on your own ride, buy the parts and take it to a mechanic. It's a straight forward job - no special mb tools required.
i replaced with OE rotors / bosch brake pads , they didn't have any vibration or pulsing just warped
https://mbworld.org/forums/5868689-post55.html
