2014 - Lost My Sound!
1 Post
2014 E350, 2012 SL550
The love affair with my new '14 has ended, at least temporarily. I have lost the sound from all sources (Disc, IPOD, Radio, NAVI, BT). It was working, then crackled and went away. All the COMAND displays are fine, showing that music is playing but there is no sound.
Checked the fuse diagram and found 4 or 5 fuses associated with sound or radio. Was able to check all but one which I could not reach without tearing the trunk apart (definite design flaw).
Any ideas? I go to the dealer on Wed. The dealer is 60 miles away. I'd like to avoid the trip if I can. I fear this is going to turn into one of those multiple trip repairs, since they are unlikely to have the part in stock and will have to order from Germany.
Regards,
Don
Regards,
Don
don, i wouldn't worry too much about this. it doesn't sound too complicated. did you try some simple troubleshooting first?
* there is a mute button on the steering wheel that cuts all volume (just checking )
* the COMAND unit can be rebooted to a default state via the 'system' menu
the service dept. can check all wiring and make repairs as needed. a regional warehouse ought to be able to send any needed parts that have failed.
good luck.
good luck.
Received 2,040 Likes
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
I feel for ya man, best of luck
I am sorry to hear that about , if a fuse blows then you should see a warning message following
Anyway, you can reset Comand on your own w/o hassling engineering menu ,may be it works but there is no warranty it would not happen again .
I think paying a visit to dealer is a wise idea
well, hold on - the HK system has it's own amplifier/processor and it is not the COMAND system head unit. your post reads like COMAND is operating normally, but without sound... this assumes you have P1?
i believe there is a member here called RNBRAD that is familiar with the audio system internals. i'd bet he could send some tips on how to check the amp connections.
2014 CLS550 4Matic
My '06 C350 did that occasionally. It was a software glitch with the fiber optic system. Short-term, disconnecting the battery fixed it, but then you have redo your presets. The dealer updated my software and that fixed it.
The problem OP has could be a bad amp. This would explain why everything works but without sound.
A question to the OP: Do you still have the warning sounds the car is supposed to make, like the seat belt beeps if you start it up and don't buckle up? If all this is gone then it very well could be a bad amplifier.
Could also be something else as I had an issue with all sound disappearing after a software update and the fix was to revert back to an older software which still was newer than what I originally had.
1 Post
I'm at the dealer now. As expected, the first thing they did was update the ecu and COMAND unit. Didn't work. They're in contact with MB now and suspecting the amp. It's getting ugly.
Regards,
Don
Regards,
Don
1 Post
Nothing yet. They gave me a '14 C250 loaner and sent me home. At best it will be tomorrow before I get mine back, assuming MB agreed on their diagnosis and the part got overnighted and it turns out to be the problem. Sigh!
OT: This C250 sport sure makes me appreciate my E. The ride is bone-jarring, the interior is junk. The gas mileage is only slightly better. On the ride home from the dealer I got 29.8 mpg with the C, vs 28.0 on the way to the dealer with my E.
The engine is surprisingly responsive. This is the first turbo I've driven in my 67 years, and I am cannot get used to the lag from the single turbo. It's nearly impossible to accelerate smoothly with more than light throttle. When the turbo spools up, it kicks you in the pants.
Regards,
Don
Regards,
Don
sounds like that is the harman kardon logic 7 unit. usually those are in the trunk, with fiber cables (MOST) run to the head unit in the dash. the thing about the HK-L7 system, is that it kinda sounds like crap! wish they would ditch it and go with B&O, ML, or even Bose as the "premium" sound.
1 Post
Update:
As originally feared, the part they are convinced is the problem is not stocked in the US distribution centers, so it is on order from Germany.
Regards,
Don
Regards,
Don
When I had the problem with lost audio I also lost all warning chimes. I though all sound in the car comes thru the speakers so if that is the case (?) how do the warning chimes work if the amp is bad?
Or are there different speakers for the Comand audio and car warning chimes?
2004.7 C180 Kompressor, BMW X5, Chevrolet Camaro LT, Mercedes S, Cesna 152.
Just a stupid comment here...
1 Post
Regards,
Don
