2014 E vs S Transmission Mode
In prior years, the E mode would start the car in 2nd gear unless you stomped the pedal. In S mode, the car would start in 1st and hold the gears longer. The owner's manual described this.
In 2014, the car always starts in 1st gear and the only difference between E and S is that S still holds the gears longer. The owner's manual no longer mentions starting in 2nd gear in E mode.
Since I'm a pretty tame driver, I only noticed this because on the new dash you can see the forward gear you are in (D1, D2, etc.).
This may have been done to help address the throttle lag issue many here have complained about.
Has anyone seen this change on an earlier model?
Regards,
Don
The owner's manual on the MBUSA web site for 2014 is not the one I received with the car.
Regards,
Don
I tried that but mine always starts in 1st from a dead stop.
Regards,
Don
while on my wife's GLK350, it will start at D2 after initial engine start.
My Transmission has an intermittent D1 to D2 lag. 3 visit to dealer in a year, they always say can't reproduce the problem.
The 2015 E350 coupe loaner starts at D2. and it does not have the lag problem.
Does anyone know how to set it at D2 like 2015 model ?
- unless you floor it in S or paddle shift down then it goes to 1st.My 2014 C63 - Comfort "C" starts in 2, everything else (S, S+, M, RS) starts in 1st.
My 2006 E320 - E started in 2 and S started in 1st
In S it is first gear and the primary reverse.
The '14 E350 starts in 1st whether you are in "E" or "S" provided you come to a complete stop. This is different from pre '14 models. Unlike earlier models, the '14 has a display of the forward gear in the multifunction display allowing you to confirm this.
Regards,
Don
