Homelink...not getting green light..command unit shuts off
i followed the step on MB instructional youtube video, tried the E350 manual..tried this thread
https://mbworld.org/forums/e-class-c...home-link.html
searched the forum for no green indicator light but haven't been able to find an answer.
I was able to program my old garage open without any problems...
Steps I've done:
1) turn the car on (hit the keyless go twice without stepping on the brakes)
2) hold down buttons 1 & 3 to reset/clear clodes..at this point..the light flashes yellow
3) I hold down the remote control button and button #1 on mirror
light continues to flash yellow
after about 30-60 seconds the light turns off....no green light to signal that it accepted to code.
one thing i've also notice is that the radio/command unit will shut off too.
TIA
Press and hold buttons 1 & 3 to reset/clear codes.
Press and hold button you want to program while pressing the garage remote button. Light will flash green. If your open has rolling codes. Press the learn button on on the garage door opener. You now have 30 seconds to press the button you just programmed.
Hope this helps.
Hope this helps.
BTW, my Command only shuts off after 20+ mins and not right away.
When I programmed mine I drove my E out the garage facing toward the garage door and didn't have any problem programming my two garage doors.
I found the HomeLink signal to be a bit weak and works fine if I am approaching my garage at 20+ feet.
But the remote supplied by my garage door manufacturer was able to activate the doors even when I'm over 60+ feet away!
